Old 10-10-2011, 06:52 PM
Default Shoulder Harness Installation
I want to install shoulder harnesses in my Superformance and need to figure out where/how to secure the harnesses. I have found the belts at Finish Line. There are two straps per seat, so each need to be secured somewhere.
Can anyone help me identify a secure place to mount the harnesses?
Stan
Old 10-10-2011, 08:48 PM
Cobra Make, Engine: SPF 1474: 482 CI stroked tunnel port 427 with dual quads.
Stan,
Take a look from inside the trunk of your car and you should be able to see the factory slits made for the shoulder harness in the fiberglass (generaly centered somewhere behind the driver and passenger seats just above the height of the frame support brace). The brace will be where you can mount those shoulder harnesses. The slits are covered by the carpeted area behind your seats. Try poking an awl from the trunk through the slits so you can get an idea where the cuts need to be made. Good Luck!
"Some things just get meaner as they get older"
.....Gumball Rally :-)
Old 10-11-2011, 06:45 AM
Jerry Clayton's Avatar
or is it from the wheel well area???
Old 10-11-2011, 07:13 AM
Neutral
Sorry. Yes, Jerry is correct. The wheel well area is the proper entry point to get to those mounting points. My rear wheels were off the car and a second set of hands came in handy. Depending on the chassis number, you should also find predrilled holes in the frame. (I heard very early cars may not have them). My car has a five point seat belt system and the shoulder harness is shaped like a "Y" so I only had one attachment per side. Be sure to use some high quality fasteners!
Old 10-11-2011, 07:53 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
You have a PM...
SPFWiringDiagrams@Comcast.net
Old 10-11-2011, 09:38 AM
Cobra Make, Engine: Cutting Edge, Boss 429
Stan,
Here is another option for you. Click on the link below.
Finish Line Accessories
Old 10-11-2011, 09:40 AM
THAT is one of the most dangerous things you could do
Old 10-11-2011, 09:44 AM
Much less dangerous than having no shoulder harness. Passes tech inspection every time. Being a tall guy, keeps me in place very well, but may not be optimal for you.
Old 10-11-2011, 09:49 AM
Buzz's Avatar
There was a very heated and interesting thread a few years ago about the pros/cons of the different mounting heights and locations for a Cobra. Some learned members chimed in on opposing sides and some good points were discussed. As far as I can recall, there was never a consensus.
Tropical Buzz
Old 10-11-2011, 10:13 AM
It might pass your tech inspection but at a real race they might not even let you enter the grounds
Old 10-11-2011, 10:55 AM
Okay HotRod!
I can see where that would be a real hazzard letting me enter the grounds
Old 10-11-2011, 12:08 PM
twobjshelbys's Avatar
I had a long discussion with the folks at Shelby American. They should be attached to the roll bar (there is a bracket to do so) and you can get eye-clips. SAI asserts that they should be attached to no member with a radius less than the roll bar. If the cross member in the rear is at least that then go for it, other wise go for the roll bar.
Regarding the passenger side. They also state that they will NEVER install shoulder harnesses on the passenger side without a roll bar, regardless of attachment method. The reason is that if the car does roll, and there is no roll bar, a shoulder-harnessed passenger IS the roll bar (the belts hold you upright). The decision you have to make is whether the protection of the shoulder harnesses in the case of a front, rear or side collision outweigh the risk of a rollover. This was the final straw in the camel's back for my wife with the Cobra and she will no longer ride in it, even to the grocery store. I warn passengers and most don't use them.
I am having the same discussion right now on my Ford GT and there are some tracks that will only allow the regular 3-point belts without an interior roll cage. Some tracks take this very seriously but I am told the tracks I am likely to use allow the setup I'm getting. Your mileage may vary but that doesn't make it safe.
Most people will attach them to the tube across the back.
CSX4005LA
Old 10-11-2011, 12:10 PM
Originally Posted by BossCER View Post
Stan,
This is exactly the roll bar setup I spoke of in the previous reply. Except they have the eyelets both on the inside. To properly line up the in-board eyelet should be on the other side.
CSX4005LA
Old 10-11-2011, 12:20 PM
At the Skip Barber 3 day open wheel course, they are well below shoulder height (and some at floor level) wrapped around chassis cross-tubes.
Bosscer-you should not snot on Clayton who has driven and flown more race miles than you have street miles. Wearing harnesses.
Chas.
Old 10-11-2011, 12:36 PM
Except for the shoulder harness I really truly like his car!!!
Old 10-11-2011, 12:49 PM
No "snotting" going on here Chas. I just don't believe that banter is a one way street.
Good to know about those air miles, thank you.
Old 01-14-2012, 11:38 AM
ReMorton's Avatar
Cobra Make, Engine: SPO2089, Ford Crate 393 475 Hp
gene- who sells the Y type harness? I've checked Simpson and others no luck.
Old 01-14-2012, 12:30 PM
G-force or Sparco?
CSX4005LA
Old 01-14-2012, 12:33 PM
I purchased a set of RJS 30298-16-23 (blk camlock quick release from summit racing). They should still carry it.
Old 01-14-2012, 12:38 PM
ReMorton's Avatar
Thanks, will do.
Tags
shoulder harness
