Old 02-22-2012, 09:23 AM
MValley Snake's Avatar
Default Alternator Bracket for 351W solution
Hello All,
My MKIII came with a Ford 351/392 Stroker Crate Engine, unfortunatly the installer must have only had generic alternator mounting brackets available as they are both low quality and mis-aligned with the water pump and lower pulley.
Has anyone came up with a classy, good fitting solution (perhhaps billet aluminium)?
Thanks in advance,
Brian
Maple Valley WA.
Old 02-22-2012, 09:33 AM
Cobra Make, Engine: Superformance SPO2512 427W TKO 600/ NW Exotics 351 Cleveland/Tremec 3550-Sold
I used a March pulley/bracket setup. Low mount, passenger side. It's billet aluminum, they fit and line up correctly. I'm using the ribbed, serpentine style belt, standard rotation water pump and underdrive crank pulley. Let me know if you want me to find the part numbers.
Dana
Old 02-22-2012, 10:10 AM
Default Thanks!
I have a regular "V" Belt but if the March kit fits, I would be greatful for the part/model number.
Old 02-22-2012, 10:13 AM
I got everything from Jones Racing.
Super high quality and they are great guys!
Lightweight High Performance, One-Wire Alternators & Accessories
Old 02-22-2012, 10:27 AM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
I got mine from Kirkhams. It's a 302 but I think they have them for a 351W.
Old 02-22-2012, 11:00 AM
double-rr's Avatar
Cobra Make, Engine: HM-2005, Keith Craft 408W TKO 600 IRS
Default March Pulley Setup
I have a 351W with a March Pulley setup P/N 30380 for the driver side lower radiator hose and standard rotation water pump. Everything fit pretty well. Misalignment on the alternator pulley was ~0.100" which was adjusted with a spacer (washer) on the 7/16" alternator bolt between the head and spacer. Misalignment on the water pump pulley was about ~0.060" which I adjusted with a generic w/p spacer that was 0.062". The alternator and w/p pulley's both needed to come away from the engine. After alignment, the misalignment was only about 0.002" which is pretty good considering that there is some variance in the harmonic balancer and water pumps.
I measured the misalignment by putting a straight edge on the crank pulley (across both sides), measuring the distance to the belt on the crank pulley. Then measured the distance from the straight edge to the belt on the alternator and w/p pulleys and subtracted the distance measured on the crank pulley.
BTW, I'm using an inline radiator cap and no Harrison tank. The March pulleys are a bit pricey (~$400)
Here's pix of the setup.
Russ
Russ
Old 02-22-2012, 03:56 PM
bobcowan's Avatar
Mike Forte makes a pretty nice bracket set.
March pulleys are one of the best. But they are definitely not cheap.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 02-22-2012, 08:26 PM
Arrow
Thanks Guy's!
The March for V belt looks like the right choice for me.
Old 02-29-2012, 03:44 AM
Cobra Make, Engine: Lone Star Classics 351W bored/stroked to 393ci
I thought the March number for the alternator bracket only was 30391? Also, Ford Bronco's have an adapter that mounts to the front of the head and allows 302 brackets to be used. I'm currently looking at this one as well:
Amazon.com: Billet Aluminum Alternator Bracket, Ford 351W, 5.8: Automotive
Old 02-29-2012, 06:45 AM
Sledge's Avatar
Cobra Make, Engine: BDR #168 427W 69+K miles and counting
Call Alistair at Millerspeed--really good stuff, got it on my 351W
Millerspeed – High performance belt drive pulley systems for Chevys and Fords
Bill
"If your work speaks for itself, don't interrupt"
