| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
02-22-2012, 09:23 AM
WA
Alternator Bracket for 351W solution
Hello All,
My MKIII came with a Ford 351/392 Stroker Crate Engine, unfortunatly the installer must have only had generic alternator mounting brackets available as they are both low quality and mis-aligned with the water pump and lower pulley.
Has anyone came up with a classy, good fitting solution (perhhaps billet aluminium)?
Thanks in advance,
Brian
Maple Valley WA.
02-22-2012, 09:33 AM
OR
Cobra Make, Engine: Superformance SPO2512 427W TKO 600/ NW Exotics 351 Cleveland/Tremec 3550-Sold
I used a March pulley/bracket setup. Low mount, passenger side. It's billet aluminum, they fit and line up correctly. I'm using the ribbed, serpentine style belt, standard rotation water pump and underdrive crank pulley. Let me know if you want me to find the part numbers.
Dana
02-22-2012, 10:10 AM
WA
Thanks!
I have a regular "V" Belt but if the March kit fits, I would be greatful for the part/model number.
02-22-2012, 10:27 AM
Ut
Cobra Make, Engine: 66 Cobra
I got mine from Kirkhams. It's a 302 but I think they have them for a 351W.
02-22-2012, 11:00 AM
TX
Cobra Make, Engine: HM-2005, Keith Craft 408W TKO 600 IRS
March Pulley Setup
I have a 351W with a March Pulley setup P/N 30380 for the driver side lower radiator hose and standard rotation water pump. Everything fit pretty well. Misalignment on the alternator pulley was ~0.100" which was adjusted with a spacer (washer) on the 7/16" alternator bolt between the head and spacer. Misalignment on the water pump pulley was about ~0.060" which I adjusted with a generic w/p spacer that was 0.062". The alternator and w/p pulley's both needed to come away from the engine. After alignment, the misalignment was only about 0.002" which is pretty good considering that there is some variance in the harmonic balancer and water pumps.
I measured the misalignment by putting a straight edge on the crank pulley (across both sides), measuring the distance to the belt on the crank pulley. Then measured the distance from the straight edge to the belt on the alternator and w/p pulleys and subtracted the distance measured on the crank pulley.
BTW, I'm using an inline radiator cap and no Harrison tank. The March pulleys are a bit pricey (~$400)
Here's pix of the setup.
Russ
Russ
02-22-2012, 03:56 PM
CO
Mike Forte makes a pretty nice bracket set.
March pulleys are one of the best. But they are definitely not cheap.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
02-22-2012, 08:26 PM
WA
Thanks Guy's!
The March for V belt looks like the right choice for me.
02-29-2012, 03:44 AM
Cobra Make, Engine: Lone Star Classics 351W bored/stroked to 393ci
I thought the March number for the alternator bracket only was 30391? Also, Ford Bronco's have an adapter that mounts to the front of the head and allows 302 brackets to be used. I'm currently looking at this one as well:
Amazon.com: Billet Aluminum Alternator Bracket, Ford 351W, 5.8: Automotive
02-29-2012, 06:45 AM
CA
Cobra Make, Engine: BDR #168 427W 69+K miles and counting
Bill
"If your work speaks for itself, don't interrupt"
