Old 03-01-2012, 12:59 PM
JA COBRA's Avatar
Cobra Make, Engine: superformance 460/ stroked to 521
Default Big block 460 pcv valve
I would like to install a pcv valve on my motor but have no idea which one to use,wondering if anyone can help with a part number or make to use,i have noticed alot of different choices out there?
Thanks in advance
Old 03-01-2012, 01:45 PM
dont's Avatar
Cobra Make, Engine: SPF #1235
Here is the one that I used. It's not cheap but it looks good. Make sure that you have baffles in your valve covers.
Cobra Valley's Billet Aluminum Breathers & PCV Housings
Superformance #1235
460/T5
Old 03-01-2012, 03:19 PM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
i just bought a fram fv-202, which has the 90 degree adapter on it if you go to the summit sight you can see the engines it covers. i was given another number a purolator pv 754 which has a bigger neck but does not have the 90 degree adapter. just a note this was for my 445 fe.
Old 03-03-2012, 10:16 AM
Cobra Make, Engine: SPF roush 402
Fram FV202 - Fram PCV Valves - Application - SummitRacing.com
Old 03-03-2012, 10:44 AM
Calbullet's Avatar
Cobra Make, Engine: Superformance 460 SVO
JA COBRA I use a FV202 on my 460 too.
- Mel
