Old 06-03-2012, 03:19 PM
mattpatt's Avatar
Cobra Make, Engine: Superformance SP3033, KC SBF 427
Default PRO 5.0 or Steeda Triax w. TKO600
I have the stock shifter in my ~new SPF cobra (#3033). I have the Jordan standard length handle. The tranny is a TKO600. I'm thinking of upgrading to a Pro 5.0 or Steeda Triax. I've read lots of comparisons - seems like a lot of people really like both.
Anyone tried either of these with a TKO 600? And with the Jordan (I'd like to use the Jordan again)? Any info on changes in handle locations from the stock shifter? How about throw? Any other distinguishing features that would help with the decision?
thx
Matt
Old 06-03-2012, 03:44 PM
fordracing65's Avatar
I vote for the Pro 5.0, I had one and loved it, the Pro is just a strudy design, and shift quality was excellent, the attention to detail is better than the steeda.
Old 06-03-2012, 03:47 PM
Steeda Tri-Ax gets my vote.
The Pro 5.0 shifters are really transmission dependent. They work extremely well with T5's, T-45's, and 3650's. On the bigger boxes, they seem a little notchy.
Old 06-03-2012, 04:00 PM
I had it with a T5.
Old 06-03-2012, 04:55 PM
Cobra Make, Engine: Spf KC482 Pond, TKO 600
I'm very pleased with the Pro 5.0 with my TKO600 -- it felt much better than stock. I also briefly had a T5 with the Steeda in a blown Mustang and liked it, too, but I found a Pro 5.0 at a good price. Either way, it will feel better, but third gear still can be tricky -- the TKO600 is just never going to shift like a Honda S2000.
Old 06-04-2012, 02:33 AM
Cobra Make, Engine: SPF Coupe #136, 427SR FI
I would suggest you investigate the MGW shifter. It is adjustable and in many experts opionion a superior product.
Jeff
Old 06-04-2012, 06:15 AM
mattpatt's Avatar
Jeff
Anyone try the MGW with the TKO600 (and Jordan handle)?
thx
Matt
Old 06-05-2012, 03:43 AM
Matt, I had researched the shifters referenced. Actually found few SPF owners who have used the MGW. But there are some on CC and others using it with non-SPFs. There are many Factory Five guys who are using the MGW.
One of my research points was to ask Dennis Olthoff for his recommendation. Hands-down he said the MGW was his preference. My discussion was based on using with T56.
Jeff
Old 06-05-2012, 03:46 AM
IMO, every shifter has its "preferred" trans. I like the MGW in a T-56 as well, just like the Pro 5.0 in a T5/T45. My vote still goes to the Tri-Ax in a TKO 500/600.
Old 06-06-2012, 02:42 AM
Good point...and to be very clear my research was based on T56. Tri-Ax is definitely a very nice unit!
Jeff
Old 06-13-2012, 01:36 AM
PANAVIA's Avatar
I personally like the TriAx - it is a nicely made unit , and does the job well on a big box, - I use them on my T56s in both cars .
Old 10-30-2012, 06:14 PM
Cobra Make, Engine: Superformance MKIII; Roush 427IR
Fellas, is the steeda tri ax easy to install in an SPF with a TKO-600 from inside the car or would I have to remove the transmission to fit it? Any insight would be great!
Tim
Old 10-30-2012, 11:57 PM
JLip's Avatar
I just put a PRO-5 in my SPF/TKO6oo and real, really like it. It was tight on installing but was able to get it in without removing the tranny. Keep in mind, my only reference point is the stock shifter and recommendations from 3 other gear heads that have Cobra's in my area.
Old 10-31-2012, 05:22 AM
Cobra Make, Engine: BDR, 302
I have a Steeda in my Astro A5. Works great. Very smooth and solid.
Old 10-31-2012, 11:38 AM
Dimis's Avatar
Tim
I suspect you could do it by just removing the tunnel.
For the record, I bought the steeda tri-ax.
Why? Simple, because the man said so.
