Like Tree3Likes
Old 06-22-2012, 06:23 PM
Default Howe Precision Ball Joints For Superformance
Anyone using Howe ball joints to replace the stock Chrysler ball joints?
Old 06-22-2012, 07:33 PM
Ousted the cobra valley custom ball joints. Big difference in feel.
Old 06-22-2012, 07:53 PM
Would you mind explaining why you ousted the CV's and how the new ones perform?
Old 06-22-2012, 09:04 PM
Sorry, I gotta proof read better before replying.
I swapped out the originals for the cobra country custom ball joints. Big improvement.
Old 06-22-2012, 10:05 PM
Didn't know Cobra COUNTRY made bump steer correction ball joints!
Old 06-23-2012, 05:53 PM
Cobra Make, Engine: SPF, 418 Stroker
Don't know about Cobra Country, but Cobra Valley sells some improved ball joints for SPFs. Cobra Valley's R/T Super High Performance Ball Joints
Old 06-23-2012, 06:20 PM
Crap! Cobra valley!
Old 06-23-2012, 06:32 PM
Crap! Cobra valley!
Now you're cooking...
I installed them over the winter and turned out to be one of the best mods so far.
Old 06-25-2012, 06:45 PM
mattpatt's Avatar
Cobra Make, Engine: Superformance SP3033, KC SBF 427
For what it's worth I replaced the stock Superformance ball joints with the CV Ultras (pronounced bump-steer and front end shimmy at ~60 - 65 mph). Noticeable improvement in bump steer and shimmy - and also some reduction in steering effort. They seem fine to me.
Old 06-27-2012, 04:31 AM
Neutral
I will be installing the Howe ball joints and will report back on them. I first saw these on Shelby built Mustangs , 2005 and up. When I visited Shelbys facility, the techs there said they are the best money can buy. Howe joints are also used thru out circle track racing, including Nascar. They do require a bit more maintenance.....grease every 3000 miles of street use with low friction grease. Use of standard grease will ruin them. Lash should be reset every 10000 miles of street use or annually. Cost is $70 per ball joint. They are available in OEM lengths plus lengths longer and shorter.
Old 06-27-2012, 05:53 AM
Cobra Make, Engine: SPF 1233-396C.I. Windsor
Neutral
The Howe ball joint is the highest quality ball joint on the market. The part number that fits our Superformance cars is 22320.. It will not require any more maintenance the the QA1 ball joint from Randall Thomas and does not require the special tools that the QA1 ball joint needs for adjustment. It is also available with a steel cap ( add "S" too the part number). The thought process around here is that the steel cap expands less than the aluminum cap and the adjustment remains more constant. I give Randall a lot of credit with all his upgrades for our cars, this is just a higher cost option, but in my mind it would be my first choice.
Bxx1 likes this.
Mike Beamish / Northern Racing Products Superformance service & installation.
Old 07-03-2012, 11:54 AM
PANAVIA's Avatar
I have a set of the Howes on order and will Road Test in my SPF. - cant wait!!!
Bxx1 likes this.
Old 07-04-2012, 02:06 PM
The problem I see with the Howe Ball Joints is that they are a pure race product. They do not even have a dust boot. It seems to me that for most of us who street drive our cars, they would not be a great solution. Racing ball joints are designed for maximum performance for X number of laps, not for cars that are driven a few thousand miles a year.
Old 07-04-2012, 04:05 PM
Kenm4187's Avatar
Cobra Make, Engine: SPF# 2560
I had a failure with the stock ones and it caused a lot of damage. I switched to the Howe ball joints, but still change them every year (I auto-x). The last time I went to the longer ball joints on the bottom to help the geometry in the front end when I lowered it. I know Cobra Valley also has some aftermarket ball joints, but I have not tried those.
Ken 2560
Old 07-04-2012, 05:33 PM
Ken 2560
Ken,
What was the reason you changed length on lower, roll center, camber gain, bump steer? Once I installl the Howe ball joints, I too plan on changing ball joint heights for geometry changes.
Old 07-04-2012, 06:14 PM
Kenm4187's Avatar
Ken,
I just did some quick measurements, but I changed them due to roll centers. Now I am running a 10-1/2 wheel in front and I want to change the upper and lower arms so they are longer and I can change the backspacing in the wheel. I already added power steering and changed to the inner hole for the steering arm so bump steer has not been an issue.
Ken 2560
Old 07-05-2012, 05:59 AM
Regarding the dust boots, Howe makes an optional dust boot for this type of ball joint. On one of my customers car we just used the dust boot off of the Chrysler ball joint with no issues. I replaced the oem ball joints with QA1 ball joints and the customer was very pleased with the results. If you think the factory supplied ball joints are a high quality piece you are sadly mistaken. In quantity I used to buy these for under $9.00 apiece! The precision ball joint discussed here is rebuildable, designed to be "friction free" and lets the suspension move freely. Until you have one of these in your hands, you cannot understand the overall benefit they offer. Whether you use Cobra Valley, QA1 or Howe, they all are a huge improvement over the oem piece of sh#%.
Bxx1 likes this.
Old 07-05-2012, 09:35 AM
I do not think I ever implied that the factory ball joint was high quality. I was just pointing out that the Howe ball joints are designed for racing, not for street driving like most of us use our cars. If I was going to be auto-crossing regularly and was interested in changing my ball joints once a year, then then Howe product makes sense.
For the guy who puts his car on a track occasionally if at all, there are solutions that make more sense from a maintenance and longevity perspective. I am not promoting any solution nor am I trash talking the Howe product which appears to be very well made. My point is that most of us do not 'race' our cars and therefore there are more options that may make more sense.
Old 07-05-2012, 09:38 AM
Here's the manual from Shelby Performance on the Howe ball joints....different car for sure, but they are driven daily by Shelby Mustang owners.
http://www.teamshelby.com/installati...5MX-3050-U.pdf
Old 01-31-2015, 06:49 PM
Update on the Howe ball joints....2 years, 6K miles, and countless Autox runs....no issues. Removed them today to install Wilwood Mustang II spindle/hub. Never needed to add grease or reset lash. I will be replacing the top studs for a shorter length, as the Wildwood spindle is a 1/2 inch taller than stock SPF spindle.
