Old 07-04-2012, 07:14 AM
Default SPF Springs
What springs are most of you guys running for good, comfortable, (not teeth jarring) solid feeling street driving?
I'm running Cobra Valley single adjustable shocks and 350# springs front and rear and the car feels too soft. Much better than stock, but still too much up and down movement for me. On a relatively mild dip, I bottomed out the suspension with a passenger on board.
I want the car to ride firm, but don't want it to chatter my teeth.
So, what do you guys recommend? Would 400# springs make that much of a difference or should I go higher and stagger them front to back?
I ride with a pasenger 98% of the time, combined weight of the both of us is about 325 pounds.
Jim
Old 07-04-2012, 07:36 AM
Silverback51's Avatar
Cobra Valley has a chart for spring rates based on how you use your car.
I personally prefer handling over ride comfort. Currently have 400's all around on my SPF and I'm probably going to step them up to 500's.
John Hall
Old 07-04-2012, 12:01 PM
dont's Avatar
Cobra Make, Engine: SPF #1235
If you have the QA1 shocks try turning the dial up for a firmer ride.
Superformance #1235
460/T5
Old 07-04-2012, 02:00 PM
Already done that.
John Hall
Old 07-04-2012, 02:18 PM
Cobra Make, Engine: Superformance #522
450 front / 400 rear assuming you have factory sway bars and 15 inch rims. I wouldn't go more unless your are competition driving.
Old 07-04-2012, 06:11 PM
I've got 17 inch wheels. Do you think 450's would be too stiff?
I've adjusted the shocks firmer but it doesn't firm up bounce, only rebound.
Jim
Old 07-04-2012, 09:02 PM
I have the 450s all the way around, and run 15 inch rims on the street and 17s on the track. I find that the single adjustable CV shocks with these springs can easily adjust to the smoother yet confident feel on the street using the lowers settings, and I can put on my track tires, dial up the settings and get the firmer ride for the track. The 450s seem just right.
