Old 09-21-2012, 07:35 AM
Cobra Make, Engine: year 2000 SPF 351
Default Key ignition problems
Key ignition. When turning off my key to completely off, the engine jumps like it wants to start. any input would be greatly appreciated thank you Livvn.
Old 09-21-2012, 08:55 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Just replace the ignition switch. They are known for failures. Mostly leaving you stranded somewhere.
NAPA has a replacement, wiring is a bit different. Consult Wiring Diagram for part numbers and wiring modifications.
SPFWiringDiagrams@Comcast.net
Old 09-21-2012, 09:22 AM
wrogers55's Avatar
Cobra Make, Engine: Backdraft #318, 418 CI, 532 RWHP, Mass Flow Injected, TKO600-Road Race, BMW M3 Suspension, Race Springs (Wouldn't do it again, rough on the street).
+1 on just replace the switch. NAPA has a heavy duty one that will work fine. Cheap and easy fix. Otherwise, like someone said, it is likely to strand you someplace very inconvenient and it only fails when you using it! Like the freeway at 5:30 pm, rush hours in Silicon Valley, while every one is honking and waving as they inch by.....
Wayne Rogers in Hideaway, Texas
Old 09-22-2012, 06:56 AM
Thank you.
Old 09-22-2012, 11:02 AM
jwoodard's Avatar
Thumbs up
Here's a good heavy duty switch that's easy to wire up.
Cobra Valley's Starter Key Switch
Jim Woodard
Old 09-24-2012, 01:21 AM
PANAVIA's Avatar
There are many switches that can be fitted retro-fitted with little issue.
One thing might be worth a look, is that has anything been modified from the stock SPF wiring , ?
---Steve
