Like Tree1Likes
  • 1 Post By JBCOBRA
Old 07-23-2013, 01:04 PM
Cobra Make, Engine: year 2000 SPF 351
Default Bilstein shocks install
Ok I am installing a set of Bilsteins, would anyone have an idea about how far I should run the collar up 1" 2" to start the fine tuning. I was thinking of running them up tight then putting the tires on dropping the car down and turning the collars down from there, any thoughts would greatly be appreciated thank you Michael. Tires are Good Year BB
Old 07-23-2013, 04:47 PM
I'd start them set at midpoint and go from there.
Old 07-23-2013, 04:54 PM
When I replaced mine, I turned the rears about an inch from the bottom and left the fronts all the way at the bottom. Then settled the car and began the final measurements for ride height.
Old 07-23-2013, 06:46 PM
....then put the car on scales because with all your measuring you are still not even close to getting it right
jdmrestor likes this.
Old 07-24-2013, 08:52 AM
Thank you that gives me a starting point, I will look into the scales after I get it as close as possible Michael.
Old 07-24-2013, 10:36 AM
What I quickly realized while measuring is the body on my car is not symmetrical. So even though it "looked" right the corner weights were way off.
Best $100.00 bucks I spent.
