Like Tree1Likes
  • 1 Post By jhv48
Old 08-18-2013, 07:34 AM
Cobra Make, Engine: SUPERFORMANCE #2258 402 S/R -ROUSH
Default Radiator cap ?
Hi Guys, I Owen# 2258 . i installed a recovery cooling tank to keep fluid off my garage floor. It seems that cooling fluid doesn't go back to to stock expansion tank. When i open stock tank there about !/4 inch fluid in the tank. the recovery tank never drains back. The engine runs at the right temp. , even on a 95 degree day. I'm running the stock cap do have change it out? also what lb. pressure cap should i be using? and what type of cap too.
Kenny
Old 08-18-2013, 08:58 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Which recovery tank did you install?
The JAZ tank comes in two versions: Catch tank and a Recovery Catch/Recovery tank.
A photo would be helpful.
SPFWiringDiagrams@Comcast.net
Old 08-18-2013, 09:36 AM
HI, A Mr Gasket # 9135 Overflow and Recovery Tank
Kenny
Old 08-18-2013, 09:42 AM
Neutral
Make sure you plumbed the hoses to the correct spouts. If reversed, it will fill, but not return to the system when pressure is relieved.
I looked at your recovery bottle and only find one inlet spout. And that one is up at the top. In order to be a recovery tank, it should have the inlet at the bottom and the overflow outlet near the top. This one just looks like an overflow catch can. Check out #9133. You'll see two spouts.
Blas likes this.
Old 08-18-2013, 11:37 AM
Blas's Avatar
Good catch !
Old 08-18-2013, 03:52 PM
Thanks for the info! Already order a 9133
Kenny
Old 08-19-2013, 08:04 AM
Archrms's Avatar
Cobra Make, Engine: Superformance SPF#2572, 427 S/O 2X4
Regardless of the type of recovery tank that you use, you will need to swap out the radiator cap on the expansion tank to a recovery type, so that it allows the fluid back into the system. I believe the stock cap on the expansion tank is a one way cap which will allow the fluid out but not back in.
Peace through superior firepower...or is it horsepower? Either way, more is always better!
Old 08-19-2013, 06:08 PM
What is the lb. cap should be use?
Kenny
