Old 11-22-2013, 01:57 PM
Default Superformance spacing between fron tires
Does anyone know the spacing between the two front tires at the tires fatest part? In other words the trailer I am looking at has a gap between the runways. I want to make sure they are not too wide and one tire is not fully on the runway.
Thanks!!
Old 11-22-2013, 02:42 PM
Senile Club Cobra Member
It will depend somewhat on what tires and wheels you have. 15" or 17/18" and tires size.
rick@autoventureusa.net
Old 11-22-2013, 03:32 PM
I have the 15" wheels
Old 11-22-2013, 08:21 PM
Calbullet's Avatar
Cobra Make, Engine: Superformance 460 SVO
How about this Superformance | MKIII Specifications
- Mel
Old 11-22-2013, 08:23 PM
Thanks but I need inside diameter. I think track is outside tire.
Old 11-22-2013, 09:45 PM
WardL's Avatar
I didn't know this, but I measured my inside "gap" on the front wheels to be 43". The outside distance was 63". I have 275/40ZA 17. I don't think the wheel diameter maters as much as the tire size. What about the rear wheels?
Old 11-23-2013, 03:43 AM
Thanks! If you get a chance please measure the back.
Thanks again!
Old 11-23-2013, 04:14 AM
"Track" is the distance to the centerline of the tire. Measure one of your fronts, subtract that amount and you have the inner dimension (nominal). Alignment, in particular camber can affect the dimension but should not be more than 1" variance.
