December 2025
Old 01-07-2014, 10:49 AM
Cobra Make, Engine: SPF 1498, 351 stroker
Default blinker not working
My blinkers are not working. If you push up or down to the on position and shake it a bit the dash bulb sometimes lights. Before I tear into this... has anyone had this problem and found a fix? Hopefully easy fix
Old 01-07-2014, 11:39 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Check your flasher unit first on the drop down fuse panel. They are prone to being chushed by the mounting bracket....
Then check the blinker fluid resovoir....&-)
SPFWiringDiagrams@Comcast.net
Old 01-08-2014, 07:40 AM
thanks
