Old 03-16-2014, 07:49 PM
Cobra Make, Engine: superformance 1022
Default Oil Change
I'm going to change my oil to prepare for the upcoming season. Currently I'm running 20-w-50 Valvoline. I plan on using Mobil Delvac 1300 15-w-40 and a bottle of Lucas Oil Stabilizer. I know it's a diesel oil but try and find a conventional oil with all those extra metals in it. The Lucas is good insurance. Any thoughts or comments are welcome. I sold my truck six weeks ago and no longer transport exotic cars. PM me if you need help with a transport as I still have connections.
Tom
Old 03-16-2014, 07:58 PM
YerDugliness's Avatar
Tom, IIRC there have been threads in which others have recommended an oil with a high ZDDP content....the name could have been Joe Gibbs or something like that. It sounds expensive but it does address those additive issues you mentioned.
Hope this has been some sort of help...try a search with ZDDP or Joe Gibbs...you might find just what you're looking for in an oil formulated for gasoline engines.
Cheers!
Dugly
YD,E./PNB
Old 03-16-2014, 08:04 PM
Thanks for the response. I'm tending toward the diesel oil because the truck I sold had over 1,665,000 miles on it through the worst hell you can imagine on Delvac and Lucas oil stabilizer. The one overhaul on the engine at 1,000,000 had no oil related failures. The liners pitted out.
Tom
Old 03-16-2014, 08:09 PM
Brent your thoughts if you see this. Thanks in advance. Tom
Old 03-16-2014, 08:29 PM
I've used Shell Rotella T 15-40 in my engine for about 6 years. However, I don't profess to be an expert.
I pulled this oils info off the web just now. It was posted in May 2013. FWIW.
ZDDP values and High Zinc Oils
Postby 540 RAT » Wed May 15, 2013 8:06 pm
Most technically inclined gearheads understand the value of real world, motor oil “load carrying capacity/film strength” testing. The results show us how various oils compare when it comes to wear protection. And we can use that information to make an informed decision as to which oil we want to select for our engines.
Though, there are some folks who are extremely set in their beliefs about what they’ve always been told and read, regarding high zinc oils providing excellent wear protection. But, the truth is, like all things in life, motor oils are NOT all created equal. And some oils are simply better than others, no matter what their zinc levels are. Anyone would have to be delusional to think otherwise. And “Wear Testing”, RATHER THAN ZINC LEVELS ALONE, can show us how various oils stack up against each other regarding wear protection capability, as you will see in the real world test data below.
Some folks, who REALLY believe the notion that more zinc in their oil will provide more wear protection, often throw a tizzy fit and get very nasty when test data shows a low zinc oil providing better wear protection than a high zinc oil. But, the fact is, behavior like that will NOT change the facts regarding what oils provide excellent wear protection and what oils do not. However, to keep everyone’s blood pressure down this time, we’ll look at ONLY HIGH ZINC OILS here. That way, all the oils are on an even playing field. However, true zinc lovers will no doubt be disappointed, because not all high zinc oils tested well, even though they all have plenty of zinc.
And keep in mind for comparison with the oils below, that earlier oil industry testing has found that above 1,400 ppm, ZDDP INCREASED long term wear, even though break-in wear was reduced. And it was also found that ZDDP above 2,000 ppm, started attacking the grain boundaries in the iron, resulting in camshaft spalling. So, no matter what zinc fans might “believe”, there is such a thing as "too much of a good thing".
The following group of 40 oils have zinc levels above 1100 ppm, and are ranked according to their “load carrying capacity/film strength”, or in other words, their “wear protection capability”, at 230*F. The tests were repeated multiple times for each oil, and even though all the results for each oil were consistent within a few percent, those results were averaged to arrive at the most accurate and representative final psi numbers shown below. And every single oil was tested EXACTLY THE SAME, so they all had the same opportunity to perform as well as their chemical formulation would allow.
But, before we get into the ranking list of those 40 oils, let’s take a closer look at one of those oils in particular. The oil is:
10W40 Summit Racing Premium Racing Oil, API SL conventional
The bottle makes some bold claims, such as:
* Double the zinc for superior flat tappet cam protection.
* The additive package contains 1800 ppm ZDDP, providing levels of protection unattainable from conventional motor oil. Provides excellent protection from metal to metal contact.
Problem is, this oil fell FAR SHORT of living up to that inflated boasting. These claims were obviously created by the Marketing Department with no regard for what this oil can actually do. This oil ranked a pathetic 85th out of the 94 new oils I’ve tested so far. And it ranked only 34th out of the 40 oils examined here. Once again, here is an oil with high levels of zinc that DID NOT help it perform very well, even among other high zinc oils. Buyer beware. Motor oils are among the worst products for false advertising.
Now let’s consider the claim on its bottle of 1800ppm ZDDP. Since Oil Companies typically don’t publish the ZDDP values of their oil, I sent this oil to Professional Lab, ALS Tribology in Sparks, Nevada, to see just what is really in it, and to see how that claim of 1800ppm ZDDP compares to reality. Here are the results that came back:
zinc = 1764 ppm
phos = 1974 ppm
NOTE: Most of the time, an oil’s zinc level is higher than its phos level, but the phos level here is greater than the zinc level. That is NOT a typo. That is how this oil’s results came back from the Lab. I’ve seen phos levels higher than zinc levels in approximately 40% of all the oils I’ve sent in for component level Lab Testing. So, it varies and just depends on a particular oil’s formulation. And the values listed below are all just the way they came back from the Lab.
If you average the zinc and phos values of this Summit Racing Oil, you come up with 1869 ppm. And that value is of course more than the 1800 ppm ZDDP claimed, so it appears they’ve averaged the values and then rounded down to the nearest 100 ppm, to be on the conservative side.
And since the ZDDP values are not usually available for most oils, we’ll calculate the ZDDP values for all the oils below, in the same manner as this oil, which should get us very close, if not right on target. But, for quick and dirty mental calculations, you can just figure the ZDDP value as approximately half way between the zinc and phos levels.
Here’s the ranking list:
Wear protection reference categories are:
*** Over 90,000 psi = OUTSTANDING protection
*** 75,000 to 90,000 psi = GOOD protection
*** 60,000 to 75,000 psi = MODEST protection
*** Below 60,000 psi = UNDESIREABLE
The higher the psi number, the better the wear protection.
1. 10W30 Lucas Racing Only synthetic = 106,505 psi
zinc = 2642 ppm
phos = 3489 ppm
ZDDP= 3000 ppm
NOTE: This oil is suitable for short term racing use only, and is not suitable for street use.
2. 10W30 Valvoline NSL (Not Street Legal) Conventional Racing Oil = 103,846 psi
zinc = 1669 ppm
phos = 1518 ppm
ZDDP = 1500 ppm
NOTE: Due to its very low TBN value, this oil is only suitable for short term racing use, and is not suitable for street use.
3. 10W30 Valvoline VR1 Conventional Racing Oil (silver bottle) = 103,505 psi
zinc = 1472 ppm
phos = 1544 ppm
ZDDP = 1500 ppm
4. 10W30 Valvoline VR1 Synthetic Racing Oil, API SL (black bottle) = 101,139 psi
zinc = 1180 ppm
phos = 1112 ppm
ZDDP = 1100 ppm
5. 30 wt Red Line Race Oil synthetic = 96,470 psi
zinc = 2207 ppm
phos = 2052 ppm
ZDDP = 2100 ppm
6. 10W30 Amsoil Z-Rod Oil synthetic = 95,360 psi
zinc = 1431 ppm
phos = 1441 ppm
ZDDP = 1400 ppm
7. 10W30 Quaker State Defy, API SL semi-synthetic = 90,226 psi
zinc = 1221 ppm
phos = 955 ppm
ZDDP = 1000 ppm
8. 10W30 Joe Gibbs HR4 Hotrod Oil synthetic = 86,270 psi
zinc = 1247 ppm
phos = 1137 ppm
ZDDP = 1100 ppm
9. 15W40 RED LINE Diesel Oil synthetic, API CJ-4/CI-4 PLUS/CI-4/CF/CH-4/CF-4/SM/SL/SH/EO-O = 85,663 psi
zinc = 1615 ppm
phos = 1551 ppm
ZDDP = 1500 ppm
10. 5W30 Lucas API SM synthetic = 76,584 psi
zinc = 1134 ppm
phos = 666 ppm
ZDDP = 900 ppm
11. 5W50 Castrol Edge with Syntec API SN, synthetic, formerly Castrol Syntec, black bottle = 75,409 psi
zinc = 1252 ppm
phos = 1197 ppm
ZDDP = 1200 ppm
12. 5W30 Royal Purple XPR (Extreme Performance Racing) synthetic = 74,860 psi
zinc = 1421 ppm
phos = 1338 ppm
ZDDP = 1300 ppm
13. 5W40 MOBIL 1 TURBO DIESEL TRUCK synthetic, API CJ-4, CI-4 Plus, CI-4, CH-4 and ACEA E7 = 74,312 psi
zinc = 1211 ppm
phos = 1168 ppm
ZDDP = 1100 ppm
14. 15W40 CHEVRON DELO 400LE Diesel Oil, conventional, API CJ-4, CI-4 Plus, CH-4, CF-4,CF/SM, = 73,520 psi
zinc = 1519 ppm
phos = 1139 ppm
ZDDP = 1300 ppm
15. 15W40 MOBIL DELVAC 1300 SUPER Diesel Oil conventional, API CJ-4, CI-4 Plus, CI-4, CH-4/SM, SL = 73,300 psi
zinc = 1297 ppm
phos = 1944 ppm
ZDDP = 1600 ppm
16. 15W40 Farm Rated Heavy Duty Performance Diesel, CI-4, CH-4, CG-4, CF/SL, SJ (conventional) = 73,176 psi
zinc = 1325ppm
phos = 1234 ppm
ZDDP = 1200 ppm
17. 15W40 “NEW” SHELL ROTELLA T Diesel Oil conventional, API CJ-4, CI-4 Plus, CH-4, CF-4,CF/SM = 72,022 psi
zinc = 1454 ppm
phos = 1062 ppm
ZDDP = 1200 ppm
18. 0W30 Brad Penn, Penn Grade 1 (semi-synthetic) = 71,377 psi
zinc = 1621 ppm
phos = 1437 ppm
ZDDP = 1500 ppm
19. 15W40 “OLD” SHELL ROTELLA T Diesel Oil conventional, API CI-4 PLUS, CI-4, CH-4,CG-4,CF-4,CF,SL, SJ, SH = 71,214 psi
zinc = 1171 ppm
phos = 1186 ppm
ZDDP = 1100 ppm
20. 10W30 Brad Penn, Penn Grade 1 (semi-synthetic) = 71,206 psi
zinc = 1557 ppm
phos = 1651 ppm
ZDDP = 1600 ppm
21. 15W50 Mobil 1, API SN synthetic = 70,235 psi
zinc = 1133 ppm
phos = 1,168 ppm
ZDDP = 1100 ppm
22. 30wt Edelbrock Break-In Oil conventional = 69,160 psi
zinc = 1545 ppm
phos = 1465 ppm
ZDDP = 1500 ppm
23. 10W40 Edelbrock synthetic = 68,603 psi
zinc = 1193 ppm
phos = 1146 ppm
ZDDP = 100 ppm
24. 15W40 LUCAS MAGNUM Diesel Oil, conventional, API CI-4,CH-4, CG-4, CF-4, CF/SL = 66,476 psi
zinc = 1441 ppm
phos = 1234 ppm
ZDDP = 1300 ppm
25. 10W30 Royal Purple HPS (High Performance Street) synthetic = 66,211 psi
zinc = 1774 ppm
phos = 1347 ppm
ZDDP = 1500 ppm
26. 10W40 Valvoline 4 Stroke Motorcycle Oil conventional, API SJ = 65,553 psi
zinc = 1154 ppm
phos = 1075 ppm
ZDDP = 1100 ppm
27. 5W30 Klotz Estorlin Racing Oil, API SL synthetic = 64,175 psi
zinc = 1765 ppm
phos = 2468 ppm
ZDDP = 2100 ppm
28. “ZDDPlus” added to Royal Purple 20W50, API SN, synthetic = 63,595 psi
zinc = 2436 ppm (up 1848 ppm)
phos = 2053 ppm (up 1356 ppm)
ZDDP = 2200 ppm
The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 24% LOWER than this oil had BEFORE the ZDDPlus was added to it. Most major Oil Companies say to NEVER add anything to their oils, because adding anything will upset the carefully balanced additive package, and ruin the oil’s chemical composition. And that is precisely what we see here. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
29. Royal Purple 10W30 Break-In Oil conventional = 62,931 psi
zinc = 1170 ppm
phos = 1039 ppm
ZDDP = 1100 ppm
30. 10W30 Lucas Hot Rod & Classic Hi-Performance Oil, conventional = 62,538 psi
zinc = 2116 ppm
phos = 1855 ppm
ZDDP = 1900 ppm
31. 10W30 Comp Cams Muscle Car & Street Rod Oil, synthetic blend = 60,413 psi
zinc = 1673 ppm
phos = 1114 ppm
ZDDP = 1300 ppm
32. 10W40 Torco TR-1 Racing Oil with MPZ conventional = 59,905 psi
zinc = 1456 ppm
phos = 1150 ppm
ZDDP = 1300 ppm
33. “ZDDPlus” added to O’Reilly (house brand) 5W30, API SN, conventional = 56,728 psi
zinc = 2711 ppm (up 1848 ppm)
phos = 2172 ppm (up 1356 ppm)
ZDDP = 2400 ppm
The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 38% LOWER than this oil had BEFORE the ZDDPlus was added to it. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
34. 10W40 Summit Racing Premium Racing Oil, API SL conventional = 59,483 psi
zinc = 1764 ppm
phos = 1974 ppm
Claimed ZDDP level on the bottle = 1800 ppm
NOTE: Summit discontinued this line of oil, as of spring of 2013.
35. “ZDDPlus” added to Motorcraft 5W30, API SN, synthetic = 56,243 psi
zinc = 2955 ppm (up 1848 ppm)
phos = 2114 ppm (up 1356 ppm)
ZDDP = 2500 ppm
The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 12% LOWER than this oil had BEFORE the ZDDPlus was added to it. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
36. “Edelbrock Zinc Additive” added to Royal Purple 5W30, API SN, synthetic = 54,044 psi
zinc = 1515 ppm (up 573 ppm)
phos = 1334 ppm (up 517 ppm)
ZDDP = 1400 ppm
The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was a whopping 36% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
37. 10W30 Comp Cams Break-In Oil conventional = 51,749 psi
zinc = 3004 ppm
phos = 2613 ppm
ZDDP = 2800 ppm
38. “Edelbrock Zinc Additive” added to Lucas 5W30, API SN, conventional = 51,545 psi
zinc = 1565 ppm (up 573 ppm)
phos = 1277 ppm (up 517 ppm)
ZDDP = 1400 ppm
The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was a “breath taking” 44% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
39. “Edelbrock Zinc Additive” added to Motorcraft 5W30, API SN, synthetic = 50,202 psi
zinc = 1680 ppm (up 573 ppm)
phos = 1275 ppm (up 517 ppm)
ZDDP = 1400 ppm
The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 22% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
40. 30wt Lucas Break-In Oil conventional = 49,455 psi
zinc = 4483 ppm
phos = 3660 ppm
ZDDP = 4000 ppm
So, as you saw above, the highest ranking high zinc oil that provided the BEST WEAR PROTECTION of this group of 40 high zinc oils, had 3000 ppm ZDDP. But, the lowest ranking high zinc oil had one third MORE ZDDP at 4000 ppm. Even though this lowest ranked oil had far more zinc in it, it provided LESS THAN HALF AS MUCH WEAR PROTECTION, making it by far the worst of all 40 oils tested. Then the 4th place oil had only 1100 ppm ZDDP, and the 7th place oil had only 1000 ppm ZDDP.
So, the results above show 2 distinct things:
1. My tester and test procedure have no problem at all showing excellent performing high zinc oils. Therefore, no one can justifiably argue that my testing somehow works against high zinc oils. The absolute fact is, my oil testing performs worst case torture testing on motor oil. So, an oil HAS TO BE GOOD to produce good results. And we saw many high zinc oils with excellent results here. So, when the naysayers slam the value of my testing, they’re also saying at the same time, that high zinc oils are no good, since my testing shows excellent high zinc oils to provide excellent protection. They can’t have it both ways.
2. This is ABSOLUTE PROOF that not all high zinc oils have equal wear protection capabilities, which is the whole point I’ve been making for well over a year now. And why would anyone think that all high zinc oils are good? Not all tires are good. Not all cylinder heads are good. Not all camshafts are good. The world just doesn’t work that way. Some high zinc oils are quite good and provide excellent wear protection, while other high zinc oils are not good at all, and provide rather poor wear protection. It just depends on the particular oil in question. And that makes it totally clear here, that you simply CANNOT predict an oil’s wear protection capability by looking only at its zinc level. Life is just NOT that simple. If you only look at zinc levels, that is no better than guessing. So, if anyone tells you that you need high levels of zinc for more wear protection, even if it comes from a Cam Company, don’t believe a word of it. Because as you can see above, they have no idea what they are talking about. Would you really want to use the 40th ranked last place oil simply because it has more zinc than the number one ranked oil here? That is just what you’d be doing if you believed the incorrect advice about only looking at zinc levels. The ONLY way to know for sure how much wear protection any given oil can provide, is to look at “dynamic wear testing under load” results, such as I have provided above.
540 RAT
U.S. Patent Holder
Member: SAE (Society of Automotive Engineers)
Link to my Motor Oil “Wear Protection Ranking List”, along with additional Motor Oil Tech FACTS (with over 23,000 “views” worldwide):
540RAT - Tech Facts, NOT Myths
540 RAT Expert
Expert Posts: 751Joined: Thu Feb 08, 2007 7:21 pmLocation: Southern California
Old 03-16-2014, 08:31 PM
Cobra Make, Engine: Unique 289 FIA, 347 stroker
Hi, Tom,
I have a 347 also, built for me by Proformance in New Jersey. The engine came with Gibbs 15W-50 motor oil, and the builders recommend that or 20W-50 or 15W-40. I use the latter grade in Chevron's Delo as I have several diesel engines to maintain and it keeps stockage simple. The Delo--and Delvac for that matter--has plenty of ZDDP, so you don't need to add it.
Old 03-17-2014, 06:23 AM
This may be a surprise to you but a diesel engine is different than a gasoline engine. 20w50 is heavy oil, you must have .0027 or greater main clearances to require 20w50. You must be running valve springs in excess of 400lb open pressure to need all the zinc and phosphorous.
Bradd Penn 15W40 from jets with free shipping will pacify all your concerns. do not use diesel oil in a gasoline engine, the additive package is incorrect. this is not 1975 anymore.
Old 03-17-2014, 07:37 AM
Thanks for the input. I'll probably use the Mobil Delvac 15-40 once the snow has cleared and I can get to the garage! 601 that is an interesting article on oil. We gotta get over to Famous Dave's for some Q and a beer! Maxx I have no idea of the clearances and spring pressures because the engine builder up in Michigan computerized his records after this particular 347 was built. It's got almost 30k on it. Tom
Old 03-17-2014, 08:11 AM
Dwight's Avatar
Smile
I have a 347 fuel injected motor in my Cobra. I have used 10-30W dinosaur oil for 40,000 miles. I tried Mobil 1 synthetic for a year but it was so thin it would leak out.
Valvoline VR1 is the oil to use in old motors that need zinc and other additives.
We know this because one of our Cobra buddy has a brother in law with Valvoline test lab.
VR1 has the same stuff in it as Joe Gibbs.
Parts store sell VR1 for $7 a qt.
Dwight
Old 03-17-2014, 08:17 AM
I would use Brad Penn oil...
Old 03-17-2014, 08:43 AM
Again thanks for the input. It seems about 50-50 as to the use of diesel oil or products like Gibbs or Penn. Brent what weight would you suggest? Tom
Old 03-17-2014, 09:07 AM
"do not use diesel oil in a gasoline engine, the additive package is incorrect. this is not 1975 anymore."
Shell Rotella T 15/40 currently includes these API ratings for spark ignition gasoline engines:
SH, SJ, SL and SM. Those ratings are in addition to their compression ignition diesel engine ratings for this same oil.
Old 03-17-2014, 09:31 AM
Originally Posted by 601HP View Post
540 RAT
U.S. Patent Holder
540 RAT Expert
I would like to see his "test setup", probably the rotating bearing with bar pulled down on top that measures the pound force before bearing failure. Remember the Dura Lube commercial, well here's the latest miracle lube TVT Green Lubricants and Protectors Bearing Test - YouTube ... and here's the truth about that test method Exposing the "One Arm Bandit" - AMSOIL Information Series - YouTube
Old 03-17-2014, 09:45 AM
This thread has provided me a great deal of information without turning into a pissing contest as to what is best and I thank you all! Tom
Old 03-17-2014, 09:53 AM
Cobra Make, Engine: SPF GT40
Have used Delvac 15-40 in my 427 Roush for 15,000 miles now. Mostly street use, but occasional track days. Change oil every 3000 miles. No problems so far.
Old 03-17-2014, 11:29 AM
Anyone agree with this regarding a fresh motor? Fast N' Loud comes to mind when a Break-In oil wasn't used.
* Break-In oils rank between number 72 and number 129. But, if you omit the highest ranked Break-In oil which is far more capable than the other Break-In oils, the rest only rank between 103 and 129. So, if you are looking for outstanding wear protection during break-in, you will be disappointed with these oils. Because they are not formulated to prevent wear, they are formulated to allow the parts to quickly “wear in”, which is totally unnecessary. You cannot stop parts from wearing-in on their own, no matter what oil you run. And we’ve seen that for many years with factory filled synthetic 5W30 Mobil 1 (which is one of the top ranked oils regarding wear protection capability) in countless thousands of brand new vehicles, that always break-in just fine. That makes so-called break-in oils unnecessary.
... just sayin'
Old 03-17-2014, 11:48 AM
1) determine oil pump rv set point. Rev engine while cold and identify point at which the oil pressure does not increase, this is the set point hopefully 65 t0 70 psig./
2) Use oil viscosity that generates 55-60 psig at 6K rpm.
3) If oil pump rv set at 60 psig find oil that genrates 55 psig of oil pressure at 6K rpm when hot. YOU DO NOT WANT YOUR OIL PUMP RV LIFTING WHEN ENGINE IS HOT (85c) AND PUMPING OIL BACK TO OIL PAN, YOU WANT OIL GOING TO ENGINE NOT THE OIL PAN!!!
I found Mobil 1 10W40 to be optimal or Brad Penn 15W40. With the mobil 1 I use 1/2 bottle of red line break in additive for grins. Not for camshaft protection but for roller bearings in lifters and rocker arm pivot point.
My test showed 67 psig at 100C at 6Krpm's with 20W50. It showed 61 psig at 100C at 6Krpms with Mobil 1 10W40 high mileage synthetic and it showed 55 psig at 100C with Mobil 1 10W30 high mileage. Each weight is about 5-7 psig difference.
Almsot forgot the oil ran 5C hotter with the 20W50 confirming it is too heavy for the engine.
Old 03-17-2014, 12:00 PM
zinc = 1247 ppm
phos = 1137 ppm
ZDDP = 1100 ppm
540 RAT
U.S. Patent Holder ...
Then go here 540RAT - Tech Facts, NOT Myths
56. 10W30 Joe Gibbs HR4 Hotrod Oil synthetic = 86,270 psi
zinc = 1247 ppm
phos = 1137 ppm
moly = 24 ppm
... but one example, the data extraction is not one-for one.
Old 03-17-2014, 12:04 PM
bobcowan's Avatar
Oil threads are always interesting to me. There's a lot myths every time. But there's some new information that pops up every once in a while.
The test article quoted above I had seen recently. I think that's great info. I have been using RP, but I might change to Valvoline.
I would never consider 15W or 20W oil in my Cobra engine. During a cold start, I want the oil to actually flow to where it's supposed to go.
I have been using a 5W-30 oil for years. No problems maintaining oil pressure lap after lap. And the bi-annual tear downs don't show significant bearing wear. So it's doing what it's supposed to do.
Heavier oil does not provide additional lubrication if you don't need. It just requires more energy and more strain on parts to move it around. You need a thick/heavy enough oil to maintain pressure in all situations. That's it; more is not better.
Last year I was reading that a slightly higher hot viscosity oil will provide better lifter stability at sustained high rpm's. I tried a 10W-40, but can't really see any difference. This year I'll go back to a 5W-30.
There are only two significant advantages to a synthetic oil - longer drain interval, and better heat resistance. If those two things are not important to you, use standard dino oil. Same results, less money.
A true synthetic oil starts with a PAO base stock, no dino oil. AFAIK, there are only 4 true synthetics on the market - and Mobile 1 is not one of them. The rest of the "synthetics" are really dino oils that have been refined enough to meet a marketing standard of "synthetic". The dino oils don't hold up as well in extreme environments, like racing and air cooled engines.
The diesel oils were somewhat better for a while. The gasoline oils reduced the ZDDP because it can damage the cats. Diesels didn't have cats, so they remained unchanged. For a while. Now some diesel angines have cats, so the ZDDP was reduced by about 25%. Not such a big deal any more. Now many diesel oils also have a certification for gasoline engines. That means there's very little difference from the gas oils for our engines. I think the big disadvantage to the diesel oils is their 15W or 20W rating.
IMO, you should choose a motor oil with the following criteria:
1. A dino oil or true synthetic according to what actually need- longevity or heat management.
2. Keep the W viscosity as low as possible.
3. Maximum viscosity high enough to maintain pressure in all situations, and no more
4. One that performs well in actual wear tests.
But, that's just my opinion. I could be wrong.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 03-17-2014, 12:16 PM
Neutral
Again I'm learning what I need to know about oils. The first number is the cold viscosity and the second number is the hot viscosity. Please correct me if I'm wrong or steer me to a site that explains it. To
