Old 04-29-2014, 05:34 PM
mnm99's Avatar
Default A few fixes needed, Help?
Hey guys,
I want to try and fix some odds and ends. I was wondering if you can point me in the right direction. My car is #467
#1 My spedo isn't working. Whats the first thing I should look for? Cable or Gauge?
#2 The drivers door has a little slop. It lines up fine, but is starting to wear the paint on the top edge because of a small droop. If I adjust the hinges it will bring it up, but then the gap may not be even. Is there a pin that needs to be replaced?
# E-brake adjustment. Whats the best way to do this? Do I need to take out the pass seat?
Thanks for your help.
