Old 05-01-2014, 12:11 PM
Cobra Make, Engine: SuperPerformance 250 / 427 +
Default Switches
The fan switch took a crap i replaced it last week with a lucus replacement it lasted less then 3 flips it bit the dust just locked up would not move at all
this switch seemed very poor in its quality any suggestions as to were i could find a decent lucus toggle replacement
thanks
what type of switches do most of you use on your projects
Old 05-01-2014, 12:46 PM
FWB's Avatar
FWB FWB is offline
Cole-Hersee.......
Fred B
Old 05-01-2014, 01:00 PM
Bill D's Avatar
100% Cole-Hersee
Old 05-01-2014, 01:10 PM
Default switches
thanks
do they offer one that is like the lucus in style if not do you guys have part # for what you use
thanks
Old 05-01-2014, 01:47 PM
mickmate's Avatar
Sounds like it needs a good relay.
mickmate
http://www.actoncustom.com/
Old 05-01-2014, 02:11 PM
FWB's Avatar
FWB FWB is offline
Originally Posted by Nobody View Post
thanks
thanks
what i use and what you may use will be two different things. i don't necessarily buy them to look like anything. i buy for the application only and match what i already have.
so i posted a link to their products page.....you have to buy to handle the particular load you have with your fan
rockers, toggles...etc.
Products | Cole Hersee - Littelfuse
Fred B
Old 05-01-2014, 04:46 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
If you are referring to the manual radiator fan switch on the dash, it is only a ground. no power load from the fans.
Unless someone did a self install without knowing how it works that is. When you say the switch "locked up" do you mean "FUSED" itself so it won't operate or just fell apart?
Consult your wiring diagram.
SPFWiringDiagrams@Comcast.net
