November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-03-2015, 03:53 AM
Default Batterybrain
Just ordered on of these, but here is not enough room to squeeze it into the battery box.
Battery Brain UK Products, Purchase and Check Out
Has anyone installed one, and would care to share how and where.
Thanks!
Dan
Old 04-10-2015, 05:54 PM
boblyon1's Avatar
Cobra Make, Engine: SPF #633, 351w stroker, Tremec 3550
I've installed the Battery Brain on my SPF. Can't quite figure out how to upload the photo. PM me with your email address and I'll send it along. I have also talked to the rep here in the US and he was very helpful. The sucker works and I am impressed with the product.
Bob
"All that is necessary for the triumph of evil is that good men do nothing" - Edmund Burke
Old 04-10-2015, 11:42 PM
PM sent
Old 04-11-2015, 03:45 PM
I don't get it. This is just a volt meter and a battery disconnect. You shouldn't have any parasitic drain on a Cobra anyway. Why would you even want this thing?
Old 04-11-2015, 11:12 PM
It comes with a remote. You push the button and it disconnects the battery. Easy and cheap theft protection without the need to open and close the boot to get to the battery switch.
Old 04-11-2015, 11:36 PM
Cobra Make, Engine: CR Cobra 3169
I work as a RAA patrolman and I'm surprised why they don't fit these to all modern vehicles. The amount of times a battery goes flat because the interior light or boot light stayed on. Even sticky solenoid for the cooling fan. But I wouldn't trust the remote key one, in case you accidently trigger it whilst it's going. The remote button is a good idea. Especially in the case of fire, or the start of an electric major short.
JD
Old 04-11-2015, 11:40 PM
JD
No risk there, it has to be connected to a wire that has 12V when the engine is running, e.g. fuel pump. Then it will not cut power even if you push the button or the voltage falls below 11.9V. Very clever design
