Like Tree1Likes
Old 05-21-2015, 12:46 PM
mrmustang's Avatar
Gold Star Contributor
Default Hi torque mini starter
Local shop has an early SPF with a 351W/5spd, they are having an issue with the starter and are looking for advice on a hi torque mini starter for this combination. I have not yet seen the car, but believe the starter has a built in solenoid attached.
Bill S.
Old 05-21-2015, 01:39 PM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
I personally have a Powermaster but I have heard very good things about these starters:
RobbMc Performance Products - Ford FE Starter
Old 05-21-2015, 02:13 PM
bingo2's Avatar
Cobra Make, Engine: RUCC, SB 331 Stroker
Tilton
Old 05-21-2015, 03:26 PM
1985 CCX's Avatar
Heard these work as well.
Planning one for my car so I can start hot.
Old 05-21-2015, 04:07 PM
RET_COP's Avatar
I was having turning over issues and replaced my stock starter with a Ford Racing Hi Torque Mini starter. It has worked flawless going on 4 seasons now.
Lou
Old 05-21-2015, 05:31 PM
Cobra Make, Engine: ERA 714
I just put this beast of a starter in. I think it will actually move the car if its in gear as it has like 4kw of power. It was not cheap but Jegs has them on sale for about $40 less than I paid.
Old 05-21-2015, 05:33 PM
It is also fully adjustable for fitting FE series engines.
Phil
Old 05-22-2015, 04:42 AM
DAVID GAGNARD's Avatar
Bill S.
Ultima Select 32281 - Starter | O'Reilly Auto Parts
O'Reilly Auto Parts,new manufacter,lifetime warranty........has spun my 13.5 to 1 compression, 331 stroker race engine over like nothing for going on 11 years now.....Todays's price is 125 bucks!!!!!!!!!!
Have one on my street car also........
or you can go to any parts house and ask for a starter for a 1995 Ford Mustang GT,302 cu in with a manual transmission.........same starter.......
romele62 likes this.
DAVID GAGNARD
Old 05-22-2015, 06:21 AM
I would stay away from a starter that is not "clockable" That means it can be spun on the housing to keep the solenoid away from the header on your particular car. Some standard started will heat soak and not start until they cool.
Bill
Old 05-22-2015, 06:48 AM
PSB's Avatar
PSB PSB is offline
Cobra Make, Engine: RCR SLC, Graziano 6-spd, LS3
What David said - the newer design of a SBF stock starter with the solenoid on the starter work great. I replaced my expensive Powermaster mini-starter that quit with one from O'Reilly's and it worked better than the Powermaster ever did.
Old 05-22-2015, 07:09 AM
bobcowan's Avatar
That's what I'v been using for years. Inexpensive, works well, and easily replacable.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 05-22-2015, 10:54 AM
mrmustang's Avatar
Oreilly's it is, thanks David.
Bill S
Old 05-22-2015, 01:33 PM
Bestest part of all, when I bought 2 of them way back when??? they were 70 bucks a pop!!!!!!!!and lifetime warranty!!!!!!!!!
Been on 2 different cars with 4 different sets of headers and no heat soak or any other problems..........
BTW: some companies like Jegs/Summit advertise this exact same starter as a "Ford MotorSport High Performance" starter @ 200+ bucks.....same exact starter with a different sticker on them,I've had both on my workbench side by side.......
DAVID GAGNARD
Old 05-22-2015, 01:40 PM
1985 CCX's Avatar
Headed to the auto store.
Great advice!
Old 05-22-2015, 04:32 PM
Senile Club Cobra Member
We have used these with success....cheap also! DB Electrical - Automotive Mini - Hi Torque
rick@autoventureusa.net
Old 05-23-2015, 11:05 AM
If it has a Quicktime bellhousing, only a few starters will fit. You will need to find that out first.
Old 11-23-2015, 07:30 AM
Cobra Make, Engine: Backdraft Cobra RT3, Roush 427R Crate Engine, Tremec 6-Speed Transmission
David Gagnard's post on 5/22/15 was a life-saver for me. The Powermaster Mastertorque starter that came with the Roush 427R (550 HP) engine failed after only 900 original miles. One of the two screws that fastened the face plate to the starter motor stripped upon starting the engine. This caused the motor to shift such that the starter gear would not engage with the flywheel ring gear. As a retired design engineer, I plan to review this failure with Powermaster along with the fact that Powermaster has no distributor in the Phoenix, AZ area--the sixth largest city in the US. I would have to order on-line.
So, I purchased an Ultima Select 32281 starter from my local O'Reilly Auto Parts Store and installed it in just a few minutes. Works great, has nearly the same performance ratings as the Powermaster, and my Backdraft Cobra is back on the road. Thanks David.
Phil
Old 11-23-2015, 10:43 AM
RET_COP's Avatar
I didn't believe it until i matched them side by side in a photo, the Ford Racing Hi Torque mini starter in my post sure looks to be the same as the Ultima Select 32281 and it wasn't cheap. Thanks David for a good find but I'll never need another one.
Lou
Old 11-23-2015, 02:56 PM
I have used a Tilton on my last three engines but am having a solenoid problem with the current one. The starter is very powerful but also very expensive ($500) so I might try something else this time. I believe they are all based on Denso internals, both the starter and my Appleton rack and pinion were getting ready to go on vacation in Scottsdale.
Old 11-24-2015, 03:22 AM
cobrajeff's Avatar
The same Ford Motorsport mini-starter I bought at a swap meet many years ago while collecting parts for my Cobra build is still spinning my Cleveland to life after eighteen years of service.
Jeff
CobraJeff
ERA P 202
