Like Tree4Likes
  • 2 Post By KirkV
  • 1 Post By SPF1061
  • 1 Post By zzmac
Old 07-23-2015, 06:11 PM
zzmac's Avatar
Cobra Make, Engine: Superformance, Roush 402R
Default Advice Needed
I get a little "clunk" sound coming from under the driver side footbox a lot of times when going over a small bump or sometimes when turning a corner. Only hear it at slow speeds but the pipes might be drowning it out at higher speeds.
I'm going to get under the car tomorrow to see if I can find anything wrong.
Not a lot to go on but has anyone had this issue before? Anything in particular I should be looking for?
Old 07-23-2015, 06:44 PM
Cobra Make, Engine: Superformance #678
Might be the exhaust support bracket
SPF1061 and DWRAT like this.
Old 07-23-2015, 07:47 PM
SPF1061's Avatar
Cobra Make, Engine: Superformance Mk III / Windsor platform
Nickel to a donut. KirkV has diagnosed your problem.
Detroit Bill likes this.
Old 07-23-2015, 07:55 PM
zzmac's Avatar
I'll owe you a honey glazed if your right.
SPF1061 likes this.
Old 07-23-2015, 08:24 PM
SPF1061's Avatar
zzmac -
It may be kinda loud and harder to tell, but do you ever hear or "feel" it under hard acceleration?
Old 07-24-2015, 03:46 AM
zzmac's Avatar
No. Not the motor mount if that's what you were thinking.
Old 09-25-2015, 07:37 PM
zzmac's Avatar
Sorry no donut. The exhaust support bracket was touching the body so I thought that was the issue. I fixed that but the clunking noise has not gone away and is probably more frequent. Most noticeable when driving at slower speed over bumps etc.., still sounds like coming from the front end.
Old 10-03-2015, 06:06 AM
zzmac's Avatar
Any other suggestions?
Old 10-03-2015, 08:12 AM
mrmustang's Avatar
Gold Star Contributor
Suspension bushings (loose ball joint, tire rod, wheel bearing). Pull the wheels off and check each one.
Bill S.
