-   Superformance (http://www.clubcobra.com/forums/superformance/)
-   -   Header to Down-Pipe Bolts/Nuts (http://www.clubcobra.com/forums/superformance/134657-header-down-pipe-bolts-nuts.html)
tortuga 09-16-2015 08:01 PM
I am constantly tightening these...do they need to be replaced, am i tightening incorrectly? Are there better bolts/nuts?
Thanks
BAsque1 09-17-2015 07:19 AM
Thanks
Red loctite I had the same problem used this product with pressure washers and problem solved so far.
Shootnride 09-17-2015 07:35 AM
I use "Prevailing Torque Lock Nuts" on mine and they stay tight. Just Google it and you'll find several suppliers.
Ted
cycleguy55 09-17-2015 08:33 AM
Ted
Our local supplier lists those as 'stoverlok' or 'stover lok' - different terminology, same concept. Clearly a nylon insert lock nut is a bad idea on something that gets hot enough to soften or melt the nylon, and this type of lock nut is answer for that application.
