Old 10-13-2015, 04:31 PM
Cobra Make, Engine: Superformance, 351 Windsor
Default Clutch identification
I have a superformance #203 that needs a clutch. 351 windsor, tremec 3550 the current unit slips during full throttle in the higher gears. I will be replcing the unit in the spring and need some help with a ford part number or a clutch from someone else as a replacement. Will inspect unit for oil or anything else in case of a rear seal leak. Someone commented that the springs in the clutch may have weakened as it was bought in 1997. Thanks
Old 10-13-2015, 06:15 PM
DWRAT's Avatar
How many miles on current clutch setup?
You will most likely need to see what exact clutch you currently have in there before buying anything new.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Old 10-13-2015, 07:02 PM
11,000 miles
