Old 04-08-2017, 06:12 PM
Cobra Make, Engine: Superformance spo2815 roush 427sr polished
Default 325 rear tires
just ordered 325/50/15 nittto 555r for the rear, I'm using MT ET drag 275/60/15 currently. stock hailebrand wheel.
Old 04-09-2017, 06:48 AM
Cobra Make, Engine: B&B Ford FE from Southern Automotive
Replaced my Michelin Pilot Sports with the Nitto 555 Extreme for two years and could not be more pleased with the performance. Very predictable performance all the way around and the 315/35/17 rears really hook up great under hard acceleration.
Old 04-11-2017, 05:34 AM
Cobra Make, Engine: Almac Cobra 427R
Just put 315/35/17 Nitto nt01 on, I think they are made of glue, super sticky.
Old 04-12-2017, 07:57 AM
Cobra Make, Engine: SPF#1867 , KC427
You should contact LUCKY-13 on this board. He recently installed the Nitto 325-50-15's on his car.I have been planning on putting a 325-50-15 on my car since back in August when we tore it down for the overhaul. I have been looking at both the Nitto and the Mickey Thompson. I currently have 17's but I purchased a set of 15" from Vintage Wheels and had them machine 3/8" off the rear wheels to help with the clearance. I expect my car will have the motor back in and be ready for a test drive in the next 60 days. We did a T-56 swap as well as many other modifications and plan to test the car with the same tire/wheel and suspension setup as it has always had. After the initial testing and miles on the new clutch we plan to pull the rear diff for gears, axle up grade and swap to the 15's tire/wheel setup.
Old 04-13-2017, 01:47 AM
325 nitto 555r is shorty in diameter then my 275/60 MT ET street. Go figure. but 2" wider and it tucked in nicely in my superformance 2815. Rear ride height set at 26.6
Old 06-28-2017, 11:56 AM
Cobra Make, Engine: SPF 239
Old 06-28-2017, 11:58 AM
325-50-15 M/T ET street Radials
Old 10-17-2017, 09:20 PM
Cobra Make, Engine: Superformance Mark III, 347 Ford
Hi,
What width 15" rim do you have for the 315/325's?
Steve
Either I am hard to get moving - or - once moving hard to stop. Hmmm, what the heck did Newton know anyway.
Old 10-18-2017, 08:16 AM
Inertia,
the wheels are original (1998) Superformance knock offs.
I believe they were listed at 15 x 9.5
Jason
Old 10-18-2017, 05:28 PM
Thanks Jason,
Looks great.
Steve
Old 10-19-2017, 05:30 PM
MOTORHEAD's Avatar
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
D-cell: do your hood vents do any good ?
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
Old 10-20-2017, 08:02 AM
Steve,
Thank you!
Motorhead,
Yes the vents work. It seems to be a -5 to 10 deg. F difference on the road.
They also reduce the heat soak of the carb when stopped dramatically. Cool down time is noticeably shorter.
Jason
