Like Tree1Likes
  • 1 Post By SPF846
Old 01-16-2023, 03:28 PM
Default Headlight relay replacement
I have an older car (#846) and I think my headlight relay has finally died. I can see it zip tied to the back of the dash. But I haven't yet figured out how I'm going to get to it. I've searched the forums here and have only found people saying they replaced it. Haven't found anything about people talking about the easiest way to get to it. Makes me wonder if it is easy to get to and I'm just missing something.
Any pro tips on how to get to it before I start taking stuff apart?
Old 01-16-2023, 05:48 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
You have an email
Blas
SPFWiringDiagrams@Comcast.net
Old 01-16-2023, 06:47 PM
Cobra Make, Engine: SPF832, 466cid
Laying on your back with your head in the footbox looking up and your feet over the back of your passenger seat. Ensure you have diagonal cutters, ziptie and relay or whatever else you might need. As you know it's the middle relay of the three. You can certainly remove the seat to make it a wee bit easier but for me I'm too lazy to go that far.
Also, it's always good practice to disconnect/Isolate the battery from anything you're working on electrically.
Old 01-16-2023, 08:25 PM
eschaider's Avatar
Why do you believe it has died?
How is this relevant to determining if it has failed?
While not proof positive, this is none the less a pretty good indicator that the other owner(s) determined that their relays were unacceptable. Of course, you should not rule out the possibility the other owner(s) may have just had it in for their relay and were just looking for a reason to get rid of/replace it.
A good indicator that it is not easy to do, is that it looks hard to do. Moreover, no one is suggesting an easy way to go about doing that hard job.
Can you turn on your headlights and/or did you check the fuse for the headlights?
Old 01-17-2023, 02:39 AM
Make it a lot easier on yourself the first time and remove the passenger seat. It’s only four nylon nuts. Provides you waaay more room to maneuver without wrenching your back. Then you can decide whether it can be handled with the seat in place for another time.
I agree that you also need to check the obvious stuff first before pitting blame on the relay. But worst case is you end up with a spare $35 relay, which isn’t a bad thing.
Old 01-17-2023, 04:57 AM
@Blas - thank you for the email.
@Everyone else. I didn't elaborate much on my original post. Parking lights come on. Low beams do not. High beams do come on but won't stay on. I went ahead and replaced all the fuses for good measure anyway, no difference. So the relay is my next target unless someone has another suggestion that I'm not thinking of.
Thank you all for the help.
Ozzie Goat likes this.
Old 01-17-2023, 01:45 PM
eschaider's Avatar
Your testing leaves the relay as the high probable failure point.
Old 01-17-2023, 01:50 PM
TRANSLATION....it's your relay.
Old 01-17-2023, 03:16 PM
eschaider's Avatar
Not for sure but, certainly a high probable candidate for failure.
Old 01-25-2023, 08:28 AM
Update (and thanks to Blas for the consultation). I replaced the relay next like I thought. I really didn't think that it would be the switch. Well, you can probably guess where this is going. Crawled under there and replaced the relay and no change. Only thing left was the switch. Pulled it out and swapped the low beams onto the pin for the parking lights and they worked. So it was the switch. New one has been ordered and should get here this week.
Old 01-25-2023, 11:42 AM
eschaider's Avatar
Although it may seem pedantic, it is usually easier on us if we go after the low hanging fruit, like potentially bad switches, first. The replacement parts can be both less expensive and easier to install because they are, the low hanging fruit. If we are correct, the cost of repair and the effort involved can be less than the alternatives — as this repair experience demonstrates so well.
Old 01-25-2023, 02:53 PM
Well I was going to say it was the switch but I didn't want to show you guys up.
Old 01-25-2023, 03:49 PM
eschaider's Avatar
