| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
| 29 |
30 |
31 |
4Likes
Post By jts359
Post By Tommy
Post By Gpfarrell
Post By 1795
02-11-2023, 05:13 AM
Cobra Make, Engine: Superformance Mk II 289
Mk II Electric Fuel Pump power wire
We’ve got SPS0061 almost together. I’ve found the black/yellow wire under the fuel tank, but even with key on I have no power to it. Starting up front, there’s power to the #12 fuse and the fuse is good. When I unplug the harness under the steering column and check the pins for the 2 black/yellow wires, I’ve got no juice. Any ideas where my missing link might be? Seems to be in the 18” between the fuse box and the harness plug.
Also, what is a good key on power source for accessories? I’m adding heated seats and a couple of well-concealed Bluetooth speakers.
Thank you!
02-11-2023, 05:52 AM
NJ
Cobra Make, Engine: 347 Ford
Your 4 legged supervisor cant wait for a ride !
02-11-2023, 06:03 AM
Yeah, she’s a natural! If only she was as helpful in Electrical as she is with Excavation!
02-11-2023, 06:31 AM
AL
This is a wild guess because I know nothing about Superformance wiring. But some cars have a device that cuts power to the fuel pump after three seconds if the engine is not running.
Tommy
Previously owned EM Cobra
02-11-2023, 09:42 AM
IL
Cobra Make, Engine: Kirkham #259
A lot of mfg’s install a roll over fuel pump device that has to be reset from time to time....
It shuts off the fuel pump in case of a roll over or crash....
Morris
02-11-2023, 09:44 AM
IL
Morris
02-11-2023, 09:55 AM
Mn
Cobra Make, Engine: SPF 1233-396C.I. Windsor
I don't get power to the pump until I activate the toggle switch on the dash designated for the fuel pump.
Mike Beamish / Northern Racing Products Superformance service & installation.
02-11-2023, 11:44 AM
Senile Club Cobra Member
NY
That is a MK III which has a fuel pump switch. The MK II ("289") does not. And there is no inertia switch/timer on the car either.
Did you receive your owner's manual and wiring diagram from Blas? An email to him may produce results.
rick@autoventureusa.net
02-11-2023, 03:25 PM
Figure it out. Among the issues, my fuse box seems to have been installed upside down. The circuits were reversed from top to bottom, but the fuses (amp ratings) were all plugged in just like the diagram indicated! More to it than that, but it was a fun day with the wiring diagram and a test meter!
02-11-2023, 05:01 PM
NY
Been there, done that!
02-11-2023, 06:06 PM
How often do the elves at SPF install the fuse box upside down?
02-12-2023, 05:42 AM
NY
Patrick,
They are built in South Africa, it's right side up there
02-12-2023, 07:50 AM
Originally Posted by 1795
Patrick,
But if they install the fuse box in upside down won't all the electricity leak out on to the floor?
