Like Tree3Likes
  • 1 Post By KarlzEE Bebout
  • 1 Post By Grubby
  • 1 Post By cycleguy55
Old 07-12-2023, 11:58 AM
Default Electric Fuel Pump
Hi Everyone
Can anyone recommend a quiet electric fuel pump for a 427 engine?
In tank or outside
Thanks
David
Old 07-12-2023, 01:02 PM
Why do you want it to be quiet? The only time you'll hear it would be when you first turn on the key. Really doubt you'd hear it with the engine running.
Davidless likes this.
Old 07-12-2023, 01:35 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
The Holley in tank pumps that mount similar to OE come in a wide range of volumes and pressures.
They are very quiet.
Holley 12-129 is a good for carbs/no return/600+ HP
John
Old 07-12-2023, 04:13 PM
cycleguy55's Avatar
I believe Carter pumps have often been recommended for those looking for quieter pumps.
Brian
Old 07-12-2023, 08:13 PM
MasterAnubis's Avatar
I wouldn't know about aftermarket in-tank pumps.
As for external, it will matter how it's mounted. Mounted on a panel will have a higher pitch and be like a speaker. A proper rubber isolation mounted on a something solid will keep it as quiet as it can be. If it's isolated right, you won't hear is while the engines running. At least in my experience.
-Shawn
Shawn
Tempe, AZ, USA
Old 07-12-2023, 10:49 PM
fordracing65's Avatar
I would definitely run a return line.
PRIDEnJOY
Old 07-13-2023, 11:46 AM
Thanks for to replys and recommendations, I guess I will stick with my Carter mechanical and try to make the plumbing fit.
