Like Tree6Likes
  • 3 Post By eschaider
  • 1 Post By Mark IV
  • 1 Post By 1795
  • 1 Post By Mark IV
Old 08-09-2023, 03:56 PM
Default Which Shifter lever position? Mid or Rear?
Hi All,
Trying to figure out which is the best shifting position on the TKX trans?
The mid would require a shorter shift lever arm while the rear is more like the original cobra, long arm.
I don't want the car to feel like I'm shifting a school bus and don't care about originality. I'd rather have the smoothest and best possible shifting.
Thanks for any input and opinions.
Old 08-09-2023, 05:30 PM
eschaider's Avatar
The mid-shift shifter position on a TKO or a TKX gives you a naturally positioned shifter, much like the T-10 shifters in the original 289 cars. You lose the long gangly, forward-bent Galaxy shifter geometry that Shelby turned around and used in the original 427 cars.
For your effort, you get a comfortable shifting, naturally positioned, intuitively located shifter pretty much where you expect it to be. You also get a very small improvement in shift quality because the portion of the internal shift rail system used in shifting from the mid-position location uses fewer internal parts, is shorter, and more rigid.
For the period-correct crowd, notably, it is also not period correct. That said, neither is a TKX five-speed OD trans ...
xb-60, cycleguy55 and Davidless like this.
Old 08-10-2023, 01:38 AM
Senile Club Cobra Member
David is getting a MK III (427 style) car. Superformance supplies the Galaxie type shifter which works fine. You learn very quickly that shifts are "up and down" rather than "back and forth" as in a 289. You can of course use the 289-type shifter and will the use the forward or mid mount.
rick@autoventureusa.net
Old 08-10-2023, 09:10 AM
Thanks Rick
Didn’t realize SF supplied the shift lever
Old 08-10-2023, 11:53 AM
Originally Posted by Davidless View Post
Thanks Rick
And the boot and ring. PM your email and I will send you the assembly manual.
Davidless likes this.
Old 08-16-2023, 04:10 PM
1985 CCX's Avatar
Dont forget the little curly reverse lockout .... 😊
Old 08-16-2023, 06:11 PM
1795's Avatar
That is if you do not plan on racing the car. I removed mine after my arm restraint (you have to wear them in an open car to keep your arms from flying outside of the car in a rollover) got caught on the reverse lockout and wrapped around the shifter
1985 CCX likes this.
Old 08-17-2023, 08:35 AM
1985 CCX's Avatar
Think my racing days are over.........
Old 08-17-2023, 04:10 PM
Plus, the "lockout" bar is cosmetic. The Tremecs do not use it.
