Like Tree7Likes
  • 1 Post By Bobcat
  • 1 Post By Tommy
  • 1 Post By eschaider
  • 1 Post By Mark IV
  • 1 Post By Mongoose930
  • 1 Post By NROTOXIN
Old 08-11-2023, 04:48 PM
Default Vacuum advance dist recommendation?
Hi All,
Thought I'd throw this out there and I'm sure this has been asked 1000x but the search doesn't work well for me.
I've decided to return my MSD billet distributor and replace it with a vacuum advance distributor, after doing a lot of research.
Can anyone recommend a high quality unit for a 427?
Old 08-11-2023, 05:30 PM
Davidless , look at a Ford Duraspark unit that has been recurved for an FE . Had mine done by an FE guy who has been racing FE's since 1987 , worked with Blair Patrick for a while and has been recurving Durasparks since 1976 .
He has also done a bunch of Durasparks for the FE guys over on the FE Forum .
If you want to contact him , let me know and I`ll post his name and contact info .
Ford Durasparks are much less than the MSD distributor and easier to get parts for .
After all , Ford used these by the thousands .
BTW , I have one , not installed yet as it's just too hot in the garage when it`s in the upper 90`s in the shade .
Davidless likes this.
Old 08-11-2023, 06:35 PM
Tommy's Avatar
If I were starting over with my engine I'd give strong consideration to Progression Ignition's programable distributor.
Tommy
Previously owned EM Cobra
Old 08-11-2023, 09:48 PM
eschaider's Avatar
This is easily the best non-EFI distributor-based ignition system I have ever seen or used; click here =>https://progressionignition.com.
A friend has a 68-muscle car with a lumpy cam and poor idle vacuum. It was extremely difficult to get a new (brand name omitted) vacuum-based system to work properly because of the very low idle vacuum the lumpy cam produced. This distributor makes it a walk in the park. There are no mechanical adjustments in the distributor.
The distributor controls ignition timing 100% electronically. Your smartphone is used for tuning and also to see real time data from the engine using the free app that runs on both iOS and Android phones
Because this distributor's timing is set using a timing map like an EFI system uses, the manifold vacuum, or lack of it at low engine speeds, had no effect at all on my friend's car. You could command the exact amount of advance you wanted, exactly where you wanted it, and the distributor did precisely what you told it to do!!
A couple of other niceties are that you access all the features with your smartphone, and when you park the car, the smartphone can disable the ignition for theft prevention. There are many other nice features, but in the simplest of terms, this is one kick-ass distributor based ignition with the programmability/adjustability of an EFI-based ignition.
PostScript:
Here is a YouTube link on how to use the theft prevention feature; click here => Theft Prevention Demo
Dominik likes this.
Old 08-12-2023, 04:01 AM
Does he do the 351w small blocks too?
Old 08-12-2023, 04:10 AM
PostScript:
Very interesting, any experience with their customer service?
Old 08-12-2023, 05:48 AM
Senile Club Cobra Member
David,
Look at a Pertronix "factory cast look" distributor, has vacuum advance and a built-in ignition system with a settable rev limiter. I have in my car and have been pleased with it. https://www.summitracing.com/parts/p...4610/make/ford
rick@autoventureusa.net
Old 08-12-2023, 07:57 AM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
I have been running the Pertronix module in my stock dual-point FE distributor for almost 5 years and I am very happy with it. You can keep the original points as a backup in case anything ever does go wrong: https://pertronixbrands.com/products...cyl-dual-point
Old 08-12-2023, 09:11 AM
eschaider's Avatar
Perhaps the best possible, never needed it!
Old 08-12-2023, 09:56 AM
I’m liking that dist, think that’s the one! I’m guessing it come with a steel gear, didn’t see anything on their site
Old 08-12-2023, 10:03 AM
eschaider's Avatar
Don't know. Best way to find out is contact them.
Old 08-12-2023, 02:41 PM
Yes, a steel gear for steel roller cam. Red the description on Summit. Again, never had needed Pertronix customer service. It might suck, but I wouldn't know.
Old 08-15-2023, 10:36 PM
Gaz64's Avatar
CB Performance Black Box.
Old 08-16-2023, 12:54 AM
eschaider's Avatar
This video was probably more meaningful for your intended use than the Theft Prevention video I linked to earlier. The video shows the idle tuning and spark map generation process. Everything is done from a smartphone while the engine is running! It is pretty impressive. Click here => Spark Map and Idle Setup. With one of the old distributor machines, even if you knew what you were doing, what he does in that video was all but impossible to achieve.
There are a number of other excellent 'how to' videos on their home page that fit into the Oh Wow category, also. Here is the Home Page link again => https://progressionignition.com
Old 08-16-2023, 05:13 AM
Cobra Make, Engine: 347 Ford
I put a Pertronix in my 347 , No problems and performs great , But I don,t do much spirited driving , I have about 2500 miles on it now , Ed
Old 08-16-2023, 08:38 AM
Cobra Make, Engine: SPF832, 466cid
From the Progression Ignitions product description:
"Distributor gear is melonized steel. Compatible with flat tappet cams and hydraulic roller cams."
Old 08-16-2023, 11:02 AM
eschaider's Avatar
Well, there you go!
Now if you want a steel gear, you can always buy one from Summit and easily put it on yourself. You even have a wide range of choices from an $8 steel gear for an FE all the way to a $149 steel gear for an SBF!
Certainly, there is something in that range that will be attractive.
Old 08-16-2023, 11:52 AM
Hmm
Melonized steel is a salt bath Ferritic Nitrocarburize procedure which uses a cyanide base. The process is accomplished at temperature around 1050F. It is usually (but not in all cases) applied to low alloy steels to form a surface generally of iron nitrides.
I'm guessing it can be used as a substitute when a steel gear is specified?
Summit:
Melonized or Hardened Steel
Heat treated for durability.
Slick surface is compatible with any type of cam.
Often used by the OEM for long life.
Generally used as the default gear on replacement distributors.
Today, GM and Ford both use melonized gears in several of their street crate engines equipped with steel camshaft cores. Because of their wear properties, melonized gears are a good fit for cars with either ductile iron camshafts or cams manufactured from billet steel. Melonized gears are compatible with conventional iron core camshafts too.
Old 08-16-2023, 12:28 PM
eschaider's Avatar
It is not clear whether you are asking a question or making a statement.
If you are asking a question, you would be better served asking it of the replacement gear provider.
If you are making a statement, and you believe it to be true, then you should act on that.
Last edited by eschaider; 08-16-2023 at 04:56 PM.. Reason: Spelling can you believe it!!!
