Old 12-07-2006, 04:23 PM
greg schroeder's Avatar
Default Amp gauge pegs
Has anyone experienced the voltage gauge pegging on 50 amps? It seems as if the regulator?, is trying to have the alternator charge a severely discharged battery even though the battery is fine. The condition is intermittent, fine one moment, then sudden load on the alternator and the belt squeals away.
Any points to first check would be appreciated.
Old 12-07-2006, 05:01 PM
xlr8or's Avatar
That would be the Ammeter not a voltage guage. I would pull the alternator and have it tested.
Old 12-07-2006, 05:23 PM
Rick Parker's Avatar
Check the regulator(remote mounted), one of the sets of points in it are probably burned and sticking, causing it to violently overcharge. I had the same thing happen at the WSCB in May and had to hike a couple of miles on foot from the hotel to get a replacement regulator at the NAPA store. If it is an internally regulated alternator, it needs to be replaced (if the regulator part cannot be serviced separately) before some wiring gets cooked.
Old 12-07-2006, 05:26 PM
Banned
Way to go, Greg. Scorch the track, run a high 10, and you tweak your charging system in the process.
Easier than half-shafts.
-Dean
Old 12-07-2006, 07:14 PM
lineslinger's Avatar
Also check and make sure the guage itself is properly grounded or if the ground wire to the guage might be loose, this happened on Smiths fuel guage in a Healy I used to have and drove me nuts till I finally figured it out.
Old 12-07-2006, 08:38 PM
ttmb's Avatar
Cobra Make, Engine: SPF 2370, Dark Silver, Roush 402R
Your Roush motor should have a voltage regulator in the alternator, thus you should bypass (disconnect) the SPF's voltage regulator. My ammeter does the same thing. I just don't worry about it because it's intermittent. If you want to do something about it, there's something on the SCOF tech. site about how to damp it out. Probably caused by the rapid switching of the solid state regulator, I hear. I freaked out the first time I saw it - but there seems to be no adverse effects (so far). Everything's fine after about 5K mi.
Tom
I love it when a plan falls apart.
Old 12-07-2006, 08:41 PM
ttmb's Avatar
...or put in a voltmeter.
Old 12-08-2006, 09:52 AM
The alternator has one wire. Would this be an indication if it is internally regulated?
Would anyone have a picture of the remote type regulator on a Superformance and/or know the approximate location to find it?
I found the associated diode in the fuse block.
Old 12-08-2006, 08:32 PM
ttmb's Avatar
My Roush came with a 1-wire, so I suspect yours did too. It's internally regulated. I suspect that's where the problem with the jumpy ammeter arises. There's information on SCOF tech about how to install it and protect your car's wiring harness.
Tom
Old 12-09-2006, 01:52 PM
This is my alternator.
Powermaster
Old 12-09-2006, 02:37 PM
Tom
I'm a bit lost on the SCOF site. Maybe I'm just slow.
Old 12-09-2006, 03:37 PM
I e-mailed and a reply was quick. I figured out some stuff. Thanks SCOF
Old 12-12-2006, 01:09 PM
Powermaster
Correction, sorry
According to Roush this would be the alternator on a 427R. It looks to be a GM alternator.
Powermaster 17294
I've now researched the problem.
The single wire from alternator in a round about way goes into amp gauge and then out to battery. The full load is being sent through the amp gauge. All that I talked with, including Powermaster, said don't do that.
My problem more than likely began because the wire out of the amp gauge going to the battery was loose and connected and disconnected at random. According to Powermaster when the wire is disconnected from the battery this is what spikes the gauge. It's a bad condition which is very hard on the voltage regulator inside the alternator.
My alternator tested to be delivering 15.8 volts. The internal voltage regulator is fried.
I ordered a new Powermaster 17294 from Summit. I'll install it and give a report as to the result soon. I'm reasonably confident this will resolve the issue. I'm going to bypass the amp gauge and use a volt gauge instead.
Old 12-12-2006, 05:13 PM
Send a message via AIM to wrench
Neutral
One work of caution, a 100 amp alternater can set a 50 amp ammeter on fire.
Age and knowledge don't always come together. Sometimes you just get the age...
Old 12-13-2006, 06:54 AM
Flyin_Freddie's Avatar
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
If it doesn't set it on fire...it'll sure make life ...er....ah......."interesting" ...for a while... Bzzzzzt....POP......sizzzzzzzzz......POP...!
...and you needn't ask how we know these little tidbits of information... trust me...
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
Old 12-13-2006, 04:00 PM
Yes, I also speak from experience.
Old 12-18-2006, 03:57 PM
The new alternator with new internal regulator works. I'm guessing my problem began due to a loose connection on the amp gauge. With it off it will destroy the alternator's internal regulator.
The Roush 427R does in fact have a Chevy type Powermaster 17294. It's a 105 amp alternator running through the 50 amp gauge. The alternator should never need to go all out given the equipment on the car, but if you have discharged battery the situation might not be good. The length of 10 gauge wire that runs all over the place probably isn't the best either.
