Old 12-24-2006, 07:09 PM
SJK2's Avatar
Cobra Make, Engine: SPF#2189
Default SPF Headlights
Are currant IE: #2000 & up stock spf headlights "DOT" or "SAE" approved if so how marked??
Tia,
Steve
Old 12-24-2006, 08:02 PM
Cobra Make, Engine: Superformance, 434, Paxton blown
I would think so. Mine passed the Pa. inspection without a problem.
However, I was not happy with the light outout and replaced them, after inspection , with a pair from Performance Unlimited.
Old 12-25-2006, 09:39 AM
I didn't have any trouble with inspections in Michigan but the stock 7" sealed beams that came in the SPF left a lot to be desired.
Replaced them with 7" H4 Hellas for a dramatic improvement. About $85.
Bought the H6024D. I didn't try the higher wattage bulbs due to the standard SPF headlight wiring. These are plenty bright and well controlled.
Hella has DOT approved replacements, the ones I selected are Euro spec. not DOT. There is a discussion of the differences on the web page. Unless the lights are inspected no one will ever notice the change.
http://www.rallylights.com/hella/7in.asp
As a note, I've never had any legal trouble with my lighting. I keep the alignments set properly and do not try to attact attention with the auxillary lighting.
Hope this helps
Merry Christmas.
Old 12-25-2006, 01:28 PM
SJK2's Avatar
Thx all......
Steve
Old 12-25-2006, 06:16 PM
Cobra Make, Engine: Superformance Brock Coupe
Jim...great tip on the Hellas. The standard SPF lights are not the most efficient. The wiring could use an upgrade too! Thanks, Badger
Old 12-04-2008, 01:16 AM
PANAVIA's Avatar
Link is dead.
new link
http://www.rallylights.com/SearchRes...CategoryID=367
Old 12-04-2008, 07:17 AM
Superformance started using standard DOT sealed beam H6024 halogen headlights from car 1663.
Mike E
Dynamic Motorsports
“The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
