Old 03-17-2007, 05:22 PM
Terry Brown's Avatar
Cobra Make, Engine: Superformance, #930, 351W/427CID 419 RWHP (before the Webers!)
Default SPF Hood Scoop Change
Anyone change out their SPF hood scoop to one like that offered by Cobra Restorers for the Weber carb setup? It's wider and taller.
I've been fighting to figure a way to close my hood with the K&N individual 48 IDA filters and they are too wide and a bit too tall. Since I have the earlier version SPF, my hood does not have the enhanced hood curvature which would make this a mute issue.
Looks like the only way to go other than cutting the velocity stacks from 2 1/2" to 1 1/2." Engine is down about as far as I can drop it. I'm not sure how 1 1/2" stacks would look.
Any help, especially if you made the mod would be appreciated. The Restorer scoop is aluminum and I would have to have the original fiberglass scoop cut off. Hate to go that way.
Help!!
Terry Brown SPF #930 427W 419 RWHP 48 IDA Webers
"Remember, your car will not be more valuable after Track Day than it is the day before the event" - Eric W. instructional presentation on Track Day safety, 05/15/2008 WSCB
Old 03-17-2007, 06:40 PM
thudmaster's Avatar
Regularly Offensive
Cobra Make, Engine: spf
Terry you can bring me the manifold and carbs and I will put it on my spf. Problem solved..........
Ed
Too close for missles, switching to guns.........
Old 03-17-2007, 07:37 PM
Ed:
Thanks buddy!! I can always count on you for help.
Maybe you can get me a deal from the fellow who is painting your car.
