08-27-2007, 04:00 PM
MO
Cobra Make, Engine: Superformance, PE 514
Car Positioning in Trailer
Greetings Folks;
I'd like to take advantage of the vast body of experience here once again to help solve a current problem. I'm curious to see what everyone has to say about positioning a cobra in a trailer for optimum weight distribution.
Hard data already in hand:
-Trailer will have a 20-foot interior floor space
-Tandem axles (3500 lbs each)
-Car weight approximately 2550
-Wheelbase of the cobra is 90 inches.
I don't yet know the weight bias of the car actually is, but plan to run it across some scales very soon to find out where the mechanical center of the car is. On second thought, I'd bet some of you know -- the car is a Superformance, the engine is a Performance Engineering 514 with a TKO 600 transmission.
Ant suggestions or lucid comments would be appreciated!
Bryon
08-27-2007, 04:19 PM
NJ
Cobra Make, Engine: West Coast Cobra, 427SO 2x4's, 630HP/600TQ
Tongue Weight.....
The car positioning will have more to do with the "tongue weight" exerted than where the car sits comfortably in the trailer. Find out what the recommended "tongue weight" is on your trailer/vehicle. Then put a scale under the front jack and move the car forwards and backwards to achieve the desired "down" weight. If you have too much weight "forward" the trailer will be squirrely & fishtailey as hell and too far back it will be lifting up on the rear of your vehicle and you get a floating, bounce ride. It's not hard to do but it takes a little bit of "jockeying" to get it dialed in. It's got to "ride" level too. You will know if it ain't right when you tow it cause it's a little scary feeling when she ain't right. I don't have a 20 ft trailer but I have two 16 footers and we have always set it up this way. My boats were the same too.
Bernie
"Shut up and take the pain".
08-27-2007, 06:36 PM
According to some trailer manufacters, if you do not have a scale to check the tongue weight, an easy way to get you "in the ball park" is hook the trailer to the tow truck, park on a level surface, measure the height of the rear bumper/hitch, load the car and move if forward till the rear bumper/hitch goes down one to one and half inches........this should be very close.....take for a test drive and move the car from that point........
Once I had my car where it needed to be, I marked the position of the front tires on the trailer floor with some paint, now when loading the car, I know exactly where my front tires need to be to get everything like it needs to be for a smooth safe ride............
DAVID GAGNARD
08-28-2007, 05:03 AM
MO
David/Bernie;
Thanks for the input!
I had heard about the "1-inch" rule previously, and might use that as a starting point.
Bryon
08-28-2007, 05:46 AM
NC
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Bryon:
Ditto to what's already been said. Additionally, after a few thousand miles of towing I've found the best way to find the correct tongue weight is to load up your car, tie it down and drive your rig. Position your car a little farther forward than you think it should be to ensure things will be stable. A light tongue can be flatout scarey, particularly when encoutering cross winds and passing or being passed by big rigs.
Once you have your car tied down, mark where the front tire is positioned with a strip of tape. If things feel good, move the car back a few inches. Otherwise, move it foreward, then continue driving. It won't take long to find out where things feel comfortable. When you get your car where you think it feels right, reposition your tape for future reference. I'm sure you'll be hauling other stuff in your trailer, such as tools, tires and supplies, so consider this weight, too.
Some other tips: Air up the rear tires of your tow vehicle to max pressure as indicated on the sidewall. Do this when the tires are cold. I've found that P-rated tires won't do the job . . . they fail . . . so I pull with LT-rated tires at 50 psi pressure. Air up the trailer tires to a similar pressure. The tires will be more durable and your rig will be more stable as a result.
Happy towing.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
08-28-2007, 06:50 AM
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Byron....as I replied on the other forum...the weight bias of the load has little to do with positioning the load in the trailer. You're looking to get 10-15% of the total weight of the trailer and all cargo on the tongue. Ideally, I like to get the lower end of the range, as I always manage to find additional equipment to load up after I get the gross weight figured out....but, I always add this additional weight in front of the axles, so it evens out.
Take your trailer and car loaded up to a trailer shop. Most of them have a scale that can measure tongue weight, and they will use that scale to help you position your car in the trailer for the proper tongue weight. You'll need the weight of the car, and the weight of the trailer...most trailers have a data placard on them. Using that information, you'll be right on target.
I've towed my SPF over 35K miles in my 20' Pace American, plus another 10K, give or take, pulling a 911 Carrera on an open trailer. Trust me...there's NOTHING that even comes close to the experience of having several thousand dollars worth of trailer, racecar, wheels and tires swaying back and forth at over 70 MPH!!!  It'll push you from one side of the hiway to the other...and don't even try to touch the brakes...or you'll lose control of the whole mess. If you're trailer tonguie weight is too little, you can look forward to this....and it ain't fun!!!
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
08-28-2007, 09:30 AM
OH
Cobra Make, Engine: SPF#1981/ 418Stroker
Who you kiddin Freddie you just load up the Margarita machine and several cases of Tequila and Mix and put the car in whereever there is room left over
Kumpie
Hey Let's do some ribs?
08-28-2007, 10:05 AM
[QUOTESome other tips: Air up the rear tires of your tow vehicle to max pressure as indicated on the sidewall. Do this when the tires are cold. I've found that P-rated tires won't do the job . . . they fail . . . so I pull with LT-rated tires at 50 psi pressure. Air up the trailer tires to a similar pressure. The tires will be more durable and your rig will be more stable as a result.
][/quote]
zacctly, always check your tire pressure before heading out(including the spare tire).....I found my tires like 4 psi more than what's marked on the tire, anything less and the trailer wants to sway in the wind........I generally put a new set of tires on about every 4 years, old tires have very little wear, but if you look at the sidewalls, you'll see small cracks and signs of dry rot.I've seen too many old tires blow out on the interstate, it just ain't worth it compared to the cost of a set of tires..........
I tow with an F-250 and on the interstate put the cruise control on 75mph and have no problems........make sure you have enough tow truck, in this case bigger IS better..........
DAVID GAGNARD
08-28-2007, 10:25 AM
Godzilla wrote...
Kumpie
Yepper...but Byron asked for the "optimum weight distribution"...he didn't mention anything about "Freddie's weight distribution"....mercifully...!  Me...? Well....everything's based on the weight of the Margarita machine...once it goes in.... well, everything else doesn't much matter after that, does it?
Ribs...? Yepper....let's discuss more. I'm thinkin' a sorta cooking competition at LCS next year...maybe at Mid-Ohio before that....or on Thursday at the hotel complex. We need judges...blind taste judges, maybe... Make it something interesting to do on Thursday just before LCS starts. Smokin' some ribs, a few brewskis...kickin' back...a few jokes and lotsa bench racin'...I'm thinkin' we may be on to something here, Brudda... Whadayathink? Let's discuss on the "other forum"...
Flyin_Freddie
08-28-2007, 11:47 AM
UT
Cobra Make, Engine: FFR 3850, 95 Cobra 5.0 EFI, IRS, Pin Drive 15" real Magnesium Halibrands & Vintage Wheels, Billboards & Mickey Thompson S/T tires, Blue/Wht Stripes, Hoops, CSX Dash, Konis, VPMs, Torsen
center the roadster door is about the center of gravity for an SPF.
If you center the door over the front trailer tires to start, you will be safe.
That will put at least 10-15% of the total weight on the tongue as mentioned above for safety.
Let us know what works best for you.
08-28-2007, 03:10 PM
MO
[quote=Flyin_Freddie] Godzilla wrote...
Great, guys -- First I plunk down a large bag of cash to buy the Cobra, then expend yet more coinage to buy a new truck and trailer to pull it. NOW I find out I have to buy a billet margarita machine too!
Thanks for the responses!
Bryon 2627
08-29-2007, 08:00 AM
Naw...naw...Byron...you don't have to buy a billet margarita machine...hell, a forged one will work just fine...even a cast one. But, stay away from those hypereautectic ones...damn things'll come apart at speed...trust me, I know this.
We got the machine...we'll have it at VIR in October with our SPF buds....you just need to get there and bring some ta-kee-ya...we'll take it from there...
Flyin_Freddie
08-29-2007, 04:07 PM
MO
Fast Freddie -- I'll stock on Ta-killya, then.
08-29-2007, 06:33 PM
Cobra Make, Engine: Lone Star 351W/408CI 525HP
I was just curious if there is a preferance to head in or back in? I just finished the Cobra and haven't trailer it much yet. ( Except to the painter) I loaded it tail first so that when I got to the painter, with the car stripped and not running, I could just roll it straight out.
08-30-2007, 06:43 AM
Depends on how your trailer is balanced. Like I said eariler, Tug, you need to have 10-15% of the total weight of both the car and trailer on the tongue. If you can get that backing in, I'd be surprised...very surprised - unless, of course, you have a very long trailer. I'd bet money you'll never get to that magic 10-15% unless you head in.
Of course, unless you're chassis has no engine and drive train installed, as it would when going to the painter.
Flyin_Freddie
08-30-2007, 07:42 AM
Freddie,
My family all live in Memphis. Well you guessed about the trailer, 28' enclosed. I did the Tim the tool Man deal (Bigger has to be better). I used it twice and am now trying to sell or trade for a 20'. Way to big for one car and pulled by a Avalanche. 4800# empty!!!! I would love to have the one for sale here on C.C. but that would be a little to far to drive. Thanks about the info, I can easily get it in backwards in a 28' but didn't think about that in a 20'.
Bet it's nice and cool in the Home Town of the King this time of year, Humidity isn't probably over 70 or 80 percent. HaHa
08-30-2007, 09:05 AM
Yepper...we're just coming out of a really hot spell...15 days of 100 degrea plus temperatures, and 80-90% realtive humidity most days. We've had 14 deaths directly attributed to the heat. Man, it's been rough here. We're just now coming out of it, like I said, but it's still in the mid-90's...humidity's down a bit, though, so it's not as bad as it sounds. Still...it'll test your deodorant, no doubt.
I'm in Germantown...my office is in Collierville, though....FedEx...
Here's a video you may like...filmed early one morning in front of the Orpheum Theater...the old Malco Theater...remember? The riding part is filmed out near Memphis State, and some down Riverside Drive...pretty neat... "Ridin' with the King"
http://video.aol.com/video/music-eri...e-king/1101242
Flyin_Freddie
09-04-2007, 08:00 PM
MN
Cobra Make, Engine: SUPERFORMANCE ROUSH427 TRI POWER
Trailer
Originally Posted by BDHE
Greetings Folks;
Bryon
BDHE,
I HAVE A 20 FT FEATHERLITE ALUM, WITH THE 2, 4600 LB AXLES, I PUT THE NOSE OF THE CAR JUST PAST THE FRONT WHEEL OF THE TRAILER SO WHEN I OPEN THE SIDE DOOR THE HEADLIGHT AND FRONT PART OF THE FENDER IS RIGHT THERE, MORE TONGUE WT, BUT THATS OK, THE TRAILER DOESNT FISHTAIL AT ALL WITH THE LITTLE EXTRA WT. UP FRONT. I WOULD RATHER BE HEAVY IN THE FRONT THAN THE REAR. I WOULD ALSO SUGGEST GEATTING ALL ALUM, IF YOU CAN AND A V FRONT TO HELP WHAT LITTLE IT CAN ON THE GAS MILEAGE. 20 FT IS PLENT BIG AND THERES ALOT OF XTRA ROOM TO MOVE AROUND IN IT WHEN THE CAR IS TIED DOWN.
MH
09-04-2007, 08:18 PM
UT
We have sold Serpent Express covers for existing flatbed trailers for users to attach.
The Featherlite is one of the better aluminum trailers made.
The SPF is pretty neutral bias front/rear so the advice above is all good.
And because of the neutral bias, one can back in and be safe on 16 or longer decks.
Be safe take no chances. Call if you want to talk details: 801-766-4651
Regards.
09-05-2007, 11:26 AM
MO
Originally Posted by BLUE427
BDHE,
MH
MH;
I already have a 20 ft Pace being built to my specs, so it's too late for the aluminum suggestion.
May I ask what truck you're pulling with, and, if it's a 3/4 ton, have you noted how much your truck squats after you've loaded your car(before with empty trailer, versus after with car loaded)?
Bryon
