Old 09-14-2007, 09:46 AM
Cobra Make, Engine: SPF 2682, Roush 427
Default SPF Trip Odometer Reset?
I can not find the trip odometer reset button,lever,knob in my SPF. I've looked way too long for it. Can anyone tell me where it should be located and where it comes out of the odometer case?
Chet
Old 09-14-2007, 09:59 AM
Cobra Make, Engine: SPF1492, Roush 402R (Sold)
Should be a small black knob just under the dash below the speedometer. Don't pull it out too far or spin it to fast, or you will break it.
James
Old 09-14-2007, 10:00 AM
wtm442's Avatar
Beam Me Up Scottie
Look directly under the speedometer ... under the bottom edge of the dashboard. There is a small black knob that you twist. Its just to the left of the cigarette lighter.
Warren
Old 09-14-2007, 10:19 AM
Cobra Make, Engine: SPF 2293, Roush 427R-228
In my car it was missing as delivered from Superformance. It turned out the hole was drilled in the dash, but the leather wasnt punched out, and the reset knob wasnt installed. They fixed it for me
Daryl
Old 09-14-2007, 12:26 PM
I'll check under the leather for a hole under the leather covering because there is not a knob to be found.
Chet
Old 09-14-2007, 12:44 PM
Cobra Make, Engine: SPF 545" stroked 460 - sold
Black tubing which connects to the trip odo clips to the back of the speedo located just above the level of the right angle gear attachment and to the right (pass) side of the speedo - if the tubing is there find the end and locate it through the hole on the under edge dash lip. It's a purely mechanical connection, be very gentle with it, I've already been through one speedo and with my new one I've decided to not mess with the trip odo
Old 09-14-2007, 02:24 PM
Don,
I just found the covered hole in the dash and the hole in the back of the speedometer for something to go into to allow the trip reset. I'm like you, save the money, all I want is a speedometer/odometer.
Chet
Old 09-14-2007, 03:45 PM
Chet, here is the speedo and trip odo attachment
Here is the tubing attached, end goes through the bottom of the dash edge
Old 09-14-2007, 04:51 PM
JTD JTD is offline
Originally Posted by CSCHWER
Don,
Chet
Take it back to the dealer.
Old 09-14-2007, 08:45 PM
Don,
My reset cable is probably on the garage floor in South Africa. The dealer said he would mail me one. Thanks for the help!
Chet
Old 09-16-2007, 03:20 PM
Cobra Make, Engine: SPF #1507 427 Dart Block Windsor
By all means, get the reset cable and attach it. It should only take a couple of minutes.
My fuel gauge is inaccurate, possibly because the dealer didn't bother to calibrate it when the fuel cell was installed, so I just reset the trip odo and gas up when I've gone 200 miles. Someday, when I replace the foam, I'll calibrate the gauge but for now, the trip odo sure is handy.
Lowell
Old 09-16-2007, 03:32 PM
My fuel guage works, but that is still a good idea. I was thinking about Tom Kirkham's speedometer/fuel gauge, but the fuel gauge display looks awful small.
Chet
Old 09-17-2007, 09:16 AM
Fattyd's Avatar
Cobra Make, Engine: SPF #1694, Royal Blue w/Vintage White Stripes, Roush 402R motor
Lowell
Couldn't agree more!! My gas gauge will bearly budge for the first 120 miles or so, then cruises through the next 40 or 50. Without that trip odo, I'm sure I'd be "fuel-less" on the side of the road somewhere. GET IT FIXED!
It Ain't The Life You Choose But The Life You Live
