| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
| 29 |
30 |
31 |
10-12-2007, 07:39 AM
NY
Cobra Make, Engine: Superformance, FRP460 Big Block
Alignment Specs anyone?
Does anyone have wheel alignment specifications for the SPF MkIII ?
Between the 460's added weight and 275 17's up front, it's a brute wrestling the steering wheel. A friend's shop has a great computerized machine that I can use...
TIA
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
10-12-2007, 07:45 AM
Beam Me Up Scottie
MA
Warren
10-12-2007, 07:46 AM
wa
Originally Posted by wtm442
Warren beat me to it.
I was even going to give him credit for posting it for me.
10-12-2007, 07:58 AM
Beam Me Up Scottie
MA
You might want to call Dennis Olthoff (704-647-9924) to ask for his suggestions with the big tires and heavy engine up front.
I do not think any alignment will reduce the amount of force necessary to turn the steering wheel. You could:
1) Get a larger dia steering wheel
2) Increase front tire pressure
3) Power steering
http://www.secondstrike.com/SecondSt...erSteering.htm
I am definitely considering the power steering this winter and I have smaller tires and a lighter engine!
Warren
10-12-2007, 05:30 PM
CA
Cobra Make, Engine: SPF# 2560
I have a small block and run 275's up front for Auto-cross. I put the power steering unit on and what a difference. It's a little pricey but nice.
Ken 2560
10-12-2007, 06:45 PM
Cobra Make, Engine: CSX 4000; Shelby aluminum FE with 58mm IDAs
Call Olthoff
3) Power steering
I agree. Give Dennis Olthoff a call--he knows his stuff.
10-12-2007, 10:18 PM
Cobra Make, Engine: ERA #698 428 Toploader
The more positive caster the car has the harder it will be to turn the wheel but the better it will return out of a turn and will be more stable on the road. About 4 degrees positive should be a good compromise.
10-13-2007, 10:52 AM
CA
You guys need to hit the weight machine and eat your spinach  .
Low speed turns (i.e. u-turn) do take a bit of effort. I can definitely see the benefit of power steering for auto-crossing.
Doug
10-14-2007, 02:19 PM
NY
Thanks all for the suggestions.
I did look into the power steering add-on when it first came out. But I thought I should do the alignment to specs (especially castor) before doing anything dra$$$tic. I think castor may be set too high.
Dennis O. has helped me in the past with brake setup for track work. I'll give him a call.
I've tried higher tire pressures. Running at the correct 25PSI, the 17's and the 425# springs make it a pretty wild (bumpy) ride with very little steering effort improvement. So, I keep it at 20PSI. Maybe higher tire pressure and lower shock dampening adjustment? Haven't tried that combo.
I put on the top today and went for a nice ride. I forgot how ugly that top was! And how all the squeaks and rattles even out the reduced exhaust noise...
Ray
New York
SPF#1052 11mpg
'08 Volvo S80 18mpg
10-14-2007, 04:27 PM
Beam Me Up Scottie
MA
My top was put into the cellar on day 1 and has not moved! Not only ugly, but at my size I can not get into the car without major surgery with the top on!
Let me know what Dennis says about alignment vs what is published in the owners manual.
Warren
