Old 01-30-2008, 08:03 AM
vanoochka's Avatar
California Dreamin Member
Send a message via ICQ to vanoochka Send a message via Yahoo to vanoochka Send a message via Skype™ to vanoochka
Default Driver side header removal
Does anyone with a Windsor block have experience removing the driver side header while the engine is still in his Superformance? I need to get mine out for coating, but there doesn't appear to be enough room between the engine and the steering column to do it.
Old 01-30-2008, 08:27 AM
Cobra Make, Engine: SPF #2459 460ci, TKO 600
I did it with a 460, you should be able to do it with a 351. Disconnected the sterring shaft, remove the forward 2 bolts holding the heat shield (so you can lift it up a little) and it will twist out from the bottom.
Thom
Old 01-30-2008, 09:24 AM
thudmaster's Avatar
Regularly Offensive
Cobra Make, Engine: spf
I just installed my windsor and we managed to get the header in without disconnecting the shaft. Although it would have made it easier if we had. Like he said just lift the panel a little and it will slide in or out whichever you want to go.........
Good luck and happy motoring
Ed
Too close for missles, switching to guns.........
Old 01-31-2008, 06:25 AM
Commissioner's Avatar
CC Member / Sponsor
Cobra Make, Engine: Slumming currently with 67 GT350
Default Header bolts
Never had to disconnect the steering shaft, but it's certainly easier to have the car on a lift and having it part way up in the air, some bolts are ez from the top, some are ez from the bottom to tighten.
