November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-01-2008, 07:07 PM
Cobra Make, Engine: Superformance, Roush 427R
Default Spring Rate?
Hey Guys,
I adjusted my Superformance preload this week-end, and it looks like the spring rate of each spring is different.
I had to crank the rear right corner to the max to get 26" (I have the 17" wheels), while the left side seems to be right in the middle.
It's the same with the front, the right side is almost totally unscrewed, while the left side is right in the middle of the adjustment.
The numbers on the spring are the same, I have the Eibach springs.
Can somebody explain this, is it possible, that the car as the wrong spring at each corners? If it's the case, where can I order a set of springs?
Thanks.
