Old 06-26-2008, 08:20 PM
Default Vacuum Booster ?
Has anyone ever installed an electric vacuum booster? I had that done today. The engine was only making 7 inches of vacuum, and the brakes we're not so good. Brakes are great now - but the unit vibrates quite a bit when it comes on. It's installed on the frame right next to the rear of the transmission. So - has anyone had any luck dampening these things or installing at a different location?
STL Mark
Old 06-26-2008, 08:47 PM
VintageUpgrades's Avatar
Cobra Make, Engine: Auto Restoration and Service
I have mounted them on the front crossmember near the oil filter with no vibration; the NOISE however was unavoidable. We only use belt driven units now.
Mitch
Old 06-26-2008, 09:51 PM
Help me out here - will it fit with my BBF in SPF.
Is there a manufacturer I should look at?
Do you have a part number and pricing?
How tough is the install?
Mark
Old 06-27-2008, 06:24 AM
Give me a call when you get a chance. I am here Tues-Sat 7am-3pm CST.
Mitch
Old 06-27-2008, 09:21 AM
FWB's Avatar
FWB FWB is offline
Default electric pump
i have a elec. vacuum pump it makes no noise and comes with rubber feet to
mount here's a link........scroll to "EV VACUUM PUMP"
http://www.metricmind.com/
it's designed for an electric vehicle that has no vacuum, it delivers a constant 18 inches, been using it for 3 years with no issues and no complaints
Old 06-27-2008, 09:45 AM
FWB, thanks for the heads up. I am going to order one to try.
Mitch
