Old 07-05-2008, 01:58 PM
Default FE Engine
Hi Guys
Does anyone know if Superformance offer a undercar exhaust system for the FE engine?
Thanks
Old 07-05-2008, 03:05 PM
Woodz428's Avatar
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
The only difference between any SPF exhaust is the header for the engine. You want a Roadster, they are the under car exhaust version. The MKIII is the S/C clone
WDZ
Old 07-05-2008, 03:19 PM
Yes Roadster version with FE and undercar exhaust, i have seen SBF engined roadster with undercar exhaust but never any FE engine roadsters. If SPF dont do a FE undercar header is there a suitable manifold from any other header manufacturers
thanks
Old 07-05-2008, 05:07 PM
Woodz428's Avatar
As an FE guy, I'm pretty sure that they offered headers because I checked into it prior to getting our cars. The FE is an older engine and isn't the most chosen one in SPF cars( maybe not in all the replicas). I think that Windsors may be the dominant choice and then 385 series followed by FEs, but that's just from memory of a few years ago. That may be why you haven't seen any. The Roadster is a much smaller volume vehicle so there are much fewer around. I would believe that is more likely why you haven't seen an FE in one. Call Hillbank, they are the owner of SPF in the U.S. and they can answer with more authority than I have. I wouldn't know what header to use, if they don't, since I am unfamiliar with the routing of the undercar system.
WDZ
