December 2025
Old 07-16-2008, 12:13 PM
Default Problems with Windshield Wipers
I was wondering if anyone has had any issues with their Windshield Wipers? I was having a problem with mine, took it in to get it looked at from my dealer, and the end result is that I have to get some new parts from Superformance. Apparently this is the 3rd cobra that this has happened to at my dealer....
Anyone else?
Old 07-16-2008, 12:48 PM
Archrms's Avatar
Cobra Make, Engine: Superformance SPF#2572, 427 S/O 2X4
What kind of problem did you have?
On mine, the drivers side does not seem to have as much tension on the arm to keep it tight against the window. It tends to flop around slightly at high speeds. I never actually used them except for the initial inspection.
Peace through superior firepower...or is it horsepower? Either way, more is always better!
Old 07-16-2008, 03:15 PM
Ha....I should have probably specified....Duh....
My passenger arm doesnt move, just the driver's side. Apparently the rod that the wipers are connected to does not reach the gear on the passenger side windshield wiper....If that makes sense.
I have no need to use them....but we were checking out the switches one day and noticed that they weren't working.
Old 07-16-2008, 03:54 PM
Got the Bug's Avatar
I've used my wipers a number of times and they were pretty effective. I know some Supeformance owners have had to bend/tweak the arm a bit for maximum contact. It also helps to apply RainX regularly if you think you might enconter moisture that would require your wipers.
Doug
Old 07-16-2008, 04:53 PM
wtm442's Avatar
Beam Me Up Scottie
You mean those shiny things with rubber on the windshield actually move? Never turned on the switch in 12K miles. Knock on wood. I do use RainX every so often on the windshield.
Warren
