Old 09-09-2008, 01:33 AM
PANAVIA's Avatar
Default Convert MK III to bolt on wheels-->?
Curious --has anyone converted the MkIII from Pin Drive (knock off) to bolt-on wheels >?
--Steve
Old 09-09-2008, 04:37 AM
1985 CCX's Avatar
Should be easy on an SPF, simply remove the adapter which is used to make the wheel a five pin hub. I think that will net you a Ford pattern five lug hub for bolt on application. Should take less than an hour.
Old 09-09-2008, 07:17 AM
If you do it, let me know I would be interested in your adapters and possibly your wheels. PM or email me- bsfx(at)aol.com
Old 09-09-2008, 07:37 AM
froggyman's Avatar
Cobra Make, Engine: SPF MKIII, SPO2891, SPO1649
Default Any Photos?
Steve,
Any more photos of your car?
Juan
Juan Lopez-Bonilla
Kentucky Cobra Club
2432 Crittenden Drive, Suite 201
Louisville, KY 40217
http://www.kentuckycobraclub.com
juan@lbrdesign.com
502-558-2904
Old 09-09-2008, 08:01 AM
Cobra Make, Engine: Superformance 2076
talk to bob at vintage wheels. he made wheels to fit my superformance #1299
Old 09-10-2008, 03:31 AM
PANAVIA's Avatar
More photos Later this week.
My 327F is going together now , heads on, timing cover on, and i am ironing out fuel injection hardware.
we used a FR Boss302 block, a repro Boss 302 oil pan, Windsor junior heads and the 1993 Cobra Manifold for EFI. 24# injectors and a nice fuel rail setup.
The goal under the hood is a "Production Look".
We lined the tunnel and heat areas with some space blanket materiel this week and i welded in a bung for my O2 sensor on my passenger side header.
working on the spacing for my tremec shifter and other trim items.
Steve
Old 09-10-2008, 03:33 AM
PANAVIA's Avatar
well let me get it on the road and iron out the FI, and if i get bored i will putt some torq thrust Ds on it.
Old 09-10-2008, 07:55 AM
Got the Bug's Avatar
Steve - What type of wheels and tires would you ultimately like to run on your car?
Doug
