Old 09-24-2008, 09:57 PM
Default Drive Shaft Hoop
Can someone tell me if my Superformance (2693) has a drive shaft hoop?
I may be participating in Run & Gun this year and the drive shaft hoop is a requirement.
Old 09-24-2008, 10:16 PM
Got the Bug's Avatar
Mark - It comes stock with a very basic drive shaft hoop. If you search under the SPF thread, you'll find a number of owners who have installed something more robust.
Doug
Old 09-24-2008, 10:34 PM
Thanks Doug - that's what I figured.
Do you know if the stock config will pass tech inspection at RNG?
Just going to try the novice class.
Old 09-24-2008, 10:36 PM
Don't know that. My guess is yes, but someone else who's taken their car through tech would have to weigh in.
Doug
Old 09-24-2008, 10:44 PM
Thanks.
I did the search as suggested.
I agree - an upgrade may be in order.
Mark
Old 09-25-2008, 04:51 AM
Cobra Make, Engine: Superformance SP02228, ROUSH 402R w/custom DiVinci Performance Carb.
You can check this product out. I have not personally seen one installed I just ran across it while researching custom side pipes.
http://buckshotracefab.net/scdt.html
Old 09-25-2008, 06:14 AM
SPF1061's Avatar
I have participated at R&G the past 2 years (Street Big Block) with the stock SPF drive shaft hoop. It passes tech fine. No problems. See you there!
Old 09-25-2008, 11:55 AM
Thanks to all - see you at RNG !
