Old 12-11-2008, 08:38 AM
Got the Bug's Avatar
Default Blocking Air Flow to Oil Cooler
Does anyone block off the air flow to the oil cooler during the winter months? The SPF cooling system is a little too efficient and without a oil thermostat I thought it might help the engine get up to temp faster on those mornings when it's just North of 40 degrees.
I thought I saw one of the local SPF (Randy or Tom?) owners running something to restrict the air flow, but I wasn't sure if it's something that they run all winter.
Doug
Old 12-11-2008, 08:41 AM
Cobra Make, Engine: SPF #1019
I cut a piece of cardboard to fit - I'm not sure how effective it is in blocking the air flow, but I think it works. And, yes, I need an oil thermostat at some point in time...
Old 12-11-2008, 08:48 AM
Rick Parker's Avatar
Clear sheet plastic, gray racer tape. I also think a lot of heat is lost or radiated through the hoses.
Old 12-11-2008, 08:57 AM
Originally Posted by Rick Parker View Post
...I also think a lot of heat is lost or radiated through the hoses.
I agree. Also I think heat is lost by the air that swirls behind the oil cooler.
Old 12-11-2008, 10:03 AM
Calbullet's Avatar
Cobra Make, Engine: Superformance 460 SVO
I fitted a cover on my cooler last year. I actually forgot to take it off last summer, temps never got hot at all. temp stayed about 5 degrees below my water temps.
Old 12-11-2008, 10:16 AM
bobcowan's Avatar
The cooler is really only needed on the track. rpm's heat oil.
On the street, you really do need a thermostat. When the oil is cold, the thermostat will pass about 10% of the oil through the cooler. That allows all of the oil to warm up at the same rate. Otherwise, the valve would open and you'de get a big slug of cold oil. That's a bad thing.
When the oil is hot, it only passes about 90% of the oil through the cooler. That little bit of bypass helps prevent pressure drop.
I use a Russell billit thermostat that opens around 180*. In the winter I cover the cooler with duct tap to block air flow. If it's less than 45-50* and I'm on the highway, I still have a tough time getting the oil much above 140*.
I'm working on a plan to alleviate this problem for good. Stay tuned.
Old 12-12-2008, 12:28 AM
PANAVIA's Avatar
Flat rubber sheet that is cut to fit,1/8th inch thick slides in from grille side ,
blocks most airlfow to oil cooler.
rubber sheet available at OSH.
Old 12-12-2008, 04:54 AM
coosawjack's Avatar
Cobra Make, Engine: Classic Roadsters '66 427 Replica-SOLD
I found out a long time ago that oil coolers are not needed on street cars.
Coosawjack
Old 12-12-2008, 06:13 AM
Banned
Bob is right. I also run an oil thermostat (Canton unit...see my gallery) and on cold mornings my oil temps still take quite a long time to get where they should be. I also use a clear plexiglass block-off plate that is held in place with two strips of velcro on either end. Clean looking and inconspicuous. It helps some.
-Dean #747
Old 12-12-2008, 06:14 AM
Bob In Ct's Avatar
I cut a piece of plexi. You can't even see it. I get the look but not the air flow.
In the summer I use a piece of plexi with a cut out in so as to restrict the air flow in order to maintain oil temp of at leat 180.
Old 12-12-2008, 07:53 AM
Archrms's Avatar
Cobra Make, Engine: Superformance SPF#2572, 427 S/O 2X4
Dean,
I could not find the pic of the oil thermostat in your gallery. Could you post a link and some additional info (cost, where to buy, etc) as I am interested in purchasing one also.
Peace through superior firepower...or is it horsepower? Either way, more is always better!
Old 12-12-2008, 08:18 AM
bobcowan's Avatar
http://store.summitracing.com/partde...5&autoview=sku
Old 12-12-2008, 08:40 AM
392cobra's Avatar
6th Generation Texan
-Dean #747
That is exactly the way I do it as well.
As a matter of fact,I got the idea from your car when it was owned in Texas.
Old 12-12-2008, 10:49 AM
Cobra Make, Engine: Cutting Edge, Boss 429
Hey guys, check this out: http://beaumontmetalworks.com/index-perf-ap.html
I use this oil cooler bypass and am very happy w/ it. You dial in the amount of oil you want to go through your cooler (from 0 to 100%). You basically can decide what temp you would like your oil to be
Old 12-12-2008, 12:55 PM
Thieleng's Avatar
Cobra Make, Engine: None at this time sold the last one
http://www.clubcobra.com/photopost/s...=&ppuser=24217
If you look just to the front of the engine, (black cylinder in between the radiator and the engine, 4 braided lines) you will see the oil thermostat used on my SPF, Stephen Bramlitt put it in for me, in the Reno area I had a hard time getting the oil even to operating temperature in the car. If you need some help on this here is his contact information:
Stephen Bramlitt
FULL THROTTLE PERFORMANCE
9728 S. Virginia St. Ste. B
Reno, NV 89511
(775) 852-0800
(775) 852-0815
stephen@fullthrottlereno.com
Old 12-12-2008, 02:14 PM
Banned
But David is a detailer's detailer. There is no way he could have made that himself.
Old 12-22-2008, 01:56 PM
Old 12-22-2008, 04:09 PM
scootter's Avatar
I didn't think you need one for a small block!!
Sorry, couldn't resist. Mines not hooked up. I have never had an oil heating problem.
Scott
Old 12-22-2008, 06:58 PM
Neutral
Default The plate comes off for track days
Old 12-22-2008, 07:09 PM
392cobra's Avatar
Richard,
That is one of the simplest,easiest and best idea I've seen in awhile.
Does it swing back and cause any problems with your paint ?
