Old 01-11-2009, 04:27 PM
Cobra Make, Engine: SPF #373,Shelby FE Alum Block #077, 488 stroker, Tunnel Port, Dual-TMP DP Holleys
Default SPF radiator petcock
I have an older Cobra (#373 Sept '98) and have not been able to locate the drain petcock found on most radiators. Up till now I have just pulled the bottom hose to drain the rad. I want to install a Zinc Anode in the rad and the preferred spot is to remove the petcock and replace with 1/4 NPT zinc anode.
I hope I do not have to pull the fans and shroud to do this.
Any imput?
Ray
Old 01-11-2009, 04:53 PM
Banned
Ray, check for a threaded brass bung, driver's side, toward the bottom.
-Dean #747
Old 01-11-2009, 11:15 PM
PANAVIA's Avatar
Beware : metric threads here.
Old 01-12-2009, 05:10 AM
more beware:
as you discovered, older cars did NOT have a rad drain petcock , such as my 156 ( built in 1996) .only way to drain mine is by removing the lower rad hose and even then it is not completely drained . sounds like your scenario, you might be looking for something that does not exist .
Later build units ( and I dont know starting at which serial/chassis number ) had drain petcocks added as a running prodcution change . Bill
Old 01-12-2009, 04:33 PM
Thanks to all that replied.
Looks like my car is early enough that it does not have a petcock. Did see a fan thermostat switch a couple inches up from bottom of rad.
I wonder if there is a alternative way to introduce a zinc anode into my coolant system. For those that don't lnow this anode is designed to slowly carrode so the alum block/radiator doesn't. About every couple of years one would replace the anode.
I hesitate to screw one into the block in place of the block petcock as this could cause an obstruction or perhaps a hot spot.
Bill we have talked in years past on scof. I have been away for awhile over there.
Any ideas or thoughts on this. I have heard that a good ground strap from rad to frame will help.
Ray
Old 01-12-2009, 04:47 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Somewhere I saw someone with a radiator cap with an anode in the center of it...Just search "radiator cap with an anode" and their all over the internet...Let us know what you find and buy...
SPFWiringDiagrams@Comcast.net
Old 01-12-2009, 07:43 PM
thudmaster's Avatar
Regularly Offensive
Cobra Make, Engine: spf
I know this is not helping you find it but boat owners have been using sacrafices for years. Check your local auto store Blas said. I bought one and put it in my Caddy; it was nearly gone in one year.
Ed
Too close for missles, switching to guns.........
Old 01-12-2009, 08:45 PM
scootter's Avatar
I bought one of the cap type ones from a place I found in the Drive magazine. I didn't fit right, so it keep leaking. It now sits in my box of spare parts.
Scott
