Old 01-25-2009, 04:43 PM
LuvDaBlues's Avatar
Question Starter motor cable
A plastic wire retainer split and allowed the red starter motor cable get too close to the header melting the insulation down to the copper. Ran to OReilly's for a new wire. All they had were 4 gauge. Superformance installs 2 gauge. I installed anyway, and all works just fine. I run a 427 S/O with a Powermaster XS Torque starter. Anybody think this will lead to problems????
Steve S
F-250 w/ 6.4 Diesel
Old 01-25-2009, 05:09 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Are you refering to the large red cable from the firewall solenoid to the starter?
If so, Send me an email offline...
SPFWiringDiagrams@Comcast.net
Old 01-25-2009, 05:14 PM
The short answer is "Yes, you should replace it with a 2 gauge wire." Why? Because the 4 gauge wire gives you additional resistance under the heavy amperage draw of cranking. This results in a lower voltage to the starter, resulting in heavier amperage draw and increased internal heat in the starter. Bottom line: The cable is not likely to catch fire and melt, but the life of your starter will be shortened.
Old 01-25-2009, 05:15 PM
Cobra Make, Engine: SPF 545" stroked 460 - sold
I would definitely replace with 2 gauge as was original with SPF wiring, that's a huge current load circuit directly to the starter from solenoid. JMHO
Old 01-25-2009, 07:38 PM
LuvDaBlues's Avatar
Originally Posted by Blas View Post
Are you referring to the large red cable from the firewall solenoid to the starter?
Yep, that cable.
But it looks like others disagree with my decision too. The 2 gauge is hard to find. OK......I'll call Dynamic.
Blas, I did send an email.
Steve S
F-250 w/ 6.4 Diesel
Old 01-25-2009, 07:49 PM
Originally Posted by LuvDaBlues View Post
Yep, that cable.
Don't stress about it. Just order them from JC Whitney and they'll be here by next weekend. Click Here and Pick Your Length:
http://www.jcwhitney.com/DEKA-BATTER...0921_10101.jcw
Old 01-25-2009, 09:05 PM
bobcowan's Avatar
USe some liquid electrical tap and cover the bare sport with 2-3 layers. Then cover the whole thing with red tape. It will work as good as new. And it would be hard to spot the repair.
Old 01-26-2009, 04:03 AM
PANAVIA's Avatar
or go hit an electrical supplier in your area. they should have red high temp heat shrink.
also Professional Truck shops in your area may be able to point you in the direction of a NAPA or similar that can get you 0/0 or 2 or ... or ...
Old 01-26-2009, 06:15 AM
LuvDaBlues's Avatar
All good ideas. Thanks for the tips.......
Steve S
F-250 w/ 6.4 Diesel
Old 01-28-2009, 09:50 PM
Madmiles442's Avatar
I found 2 gauge at Napa.
It's not just for wine anymore...
MadMiles442
Old 02-06-2009, 01:42 AM
PANAVIA's Avatar
Napa seems to have good stuff, sometimes "Parts+" Franchise houses can too.
Remember -- they can pull things from distribution if you can spec what you are looking for.
Professional Truck places also have some good stuff.
