Old 03-17-2009, 08:43 PM
Cobra Make, Engine: Superformance #858 351W SVO Crate
Default Yates 9.2 deck windsor
Does anyone know if there is a bolt on header for a yates engine in a Superformance MKIII? Currently have a 351W w/ SVO heads in the car #858. Didn't have time to call Olthoff today. Thanks.
Old 03-18-2009, 03:55 PM
PANAVIA's Avatar
which block is the Yates Block >? the 351N motorsport block >?
Old 03-18-2009, 04:14 PM
I think he's referring to Yates heads.
9.2" deck height is the same as a Cleveland. Could you find headers for a Cleveland and then put on the correct flanges?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 03-18-2009, 04:27 PM
Cobra Make, Engine: jbl
going from a crate motor to a 9.2 with yates heads which prob has the raised exhaust port would probably be similiar in height. just switch the flange out for a yates pattern at a good header shop.
may be able to weld the yates flange to the current flange and make modifications or cut portions of the old flange away, though this would move the headers out the thickness of the flange, but then use rtv instead of exhaust gasket and that goes away.
