03-27-2009, 03:39 PM
Turn signal dash indicator light not working
I got back from a drive this afternoon and noticed that the turn signal indicator on the dash wasn't working. The turn signals are working on all four corners (as is the flasher), so I'm guessing that a bulb went bad?
Doug
03-27-2009, 06:48 PM
Cobra Make, Engine: SPF#0760
Bulb or a wire, probably just the bulb. Bulb may have just pulled out of the holder and you can't see it cycle... Pull a lot of "G's" during your ride?
SPFWiringDiagrams@Comcast.net
03-27-2009, 07:40 PM
Thanks Blas. I'll take a look tomorrow. Fairly tame drive today. Just cruising for an hour or so enjoying the weather...near 70 on the Coast near Santa Cruz today  .
Doug
03-27-2009, 07:49 PM
Cobra Make, Engine: Former owner of Sp931
Come on Blas get real.........The bulb is what 1.2 grams.
You would have to pull 20 g's to dislodge that sucker and Cobra's have problems doing .8 g's....It's probably a spun main bearing..
Mcdoo
03-27-2009, 08:02 PM
Low Blinker Fluid?
03-27-2009, 09:13 PM
Low Blinker Fluid?
I guess I've got to upgrade to the racing blinker fluid.
Doug
03-27-2009, 11:22 PM
McDump- Bring on your tupperware.
I have an AMG with racing fluid in the blinkers already. --....
03-28-2009, 11:44 AM
I wiggled the little doohickey on the back of the whatchama-call-it and the dash turn signal indicator is now working.
Doug
