| 29 |
07-28-2009, 02:52 PM
Cobra Make, Engine: SPF2914 Sunset / Titanium
Has any solved the r/r SPF rattle yet?
Hi all,
I think I just to hear the dreaded r/r suspension(?) rattle / clunk noise from my SPF over bumps today. I recall this thread floating around several times in the last couple of months. Has anyone found & solved their noise yet? I just noticed at lunch, so I have not had a chance to get under the car yet.
Andrei
07-28-2009, 03:25 PM
I believe it's usually the right front differential mount or the CV joint hitting the lower control arm.
07-28-2009, 04:13 PM
Cobra Make, Engine: SPF#0760
Check your sway bar bolts, and shock bolts. And by your car number, I see you fall into the fuzzy area where there was an issue witht the bolts on the calipers not having enough loctite used during final assembly, so check those too for sure....PM me and I'll send you the details...
SPFWiringDiagrams@Comcast.net
07-28-2009, 05:25 PM
Cobra Make, Engine: superformance/427 fe ford
have you checked to make sure the sidepipe mount is not hitting the underbody?
1952 MG TD - 53 HP 1970 SS454 Chevelle - 900hp 2007 spo2669 - 485hp 2001 Spclconst. softtail - 114HP 2006 Roadglide - 88HP
sold Roadglide.....bought 09 XR 1200 - 90 hp stock
i would rather live one day as a lion, than one thousand days as a lamb.
07-28-2009, 10:36 PM
I am trying to check only a couple of things at a times, so I know for the future what actually fixed it. So far it is not the roll bar, lower control arms, side pipes, lower shock bolts or gas tank. Tomorrow night I will cross more off the list and hopefully have a quieter drive home!
07-29-2009, 12:12 AM
Isn't this what Randy Rosenberg was experiencing with his SPF? I clearly remembering him jumping up and down inside his car in order to show us some type of noise from the rear of the car.
07-29-2009, 07:43 AM
I had the same thing. #2807 I installed these rear brackets:
http://performanceunlimited.com/cobr...sionmount.html
Noise went away.
It could be the rear springs moving around in their perches. My front springs were too wide. Hillbank put in 4 new springs and shocks.
Good luck
07-29-2009, 08:45 AM
lube your sway bar where they go through the sway bar bushings.
07-29-2009, 09:33 AM
Banned
trunk bracket...rattles over bumps all the time.
07-29-2009, 10:01 AM
wa
I had this problem last Friday after I stopped for lunch.
Some A-Hole opened my gas cap and left it open.  Probably looking to see if it's real.
John Hall
07-29-2009, 01:56 PM
Cobra Make, Engine: SPF #1019
I had a SQUEEK, not a RATTLE, and it little lubrication here and there, and vuala! It's solved.
07-30-2009, 07:43 AM
Cobra Make, Engine: Superformance SP02228, ROUSH 402R w/custom DiVinci Performance Carb.
11,000 miles in 2 years not a sound.... that i can hear. each time i have had the car on a lift the springs "popped" back into place with in 10 miles.
