Old 08-06-2009, 09:05 AM
SunDude's Avatar
Default Which 8.8" differential is on my SPF?
I know from reading the Superformance MkIII owners manual 2nd ed. that the car uses an 8.8-inch Ford limited-slip differential (Traction-Lok?). But does anyone know exactly which 8.8" diff is being used? What is the part no. of the unit used by SPF?
http://www.fordracingparts.com/parts...20differential
I have chassis no. 1336.
Thanks.
Old 08-06-2009, 09:10 AM
Banned
You most likely have the same 8.8 that was also used on the Ford Thunderbird Super Coupes. At least mine does and your sequence number and build year is not that far off.
-Dean #747 (March 2000)
Old 08-06-2009, 01:40 PM
SunDude's Avatar
Yep, Superformance LLC has confirmed that my car is equipped with an 8.8-inch diff from a 1990 Ford Thunderbird SC (Supercoupe).
Does anyone know if this was a 28 or 31 spline unit?
Old 08-06-2009, 05:49 PM
Banned
SunDude, they are 28's.
The Driveshaft Shop http://www.driveshaftshop.com/ sells 31 spline half shafts, but be careful because I've heard a few situations where the replacements were not EXACTLY what was needed. Some SPF owners have combined the 31's with a Detroit Tru-Trac (sp?) posi member and this combination is about as bullet-proof as you can make the 8.8.
Also add a Steeda brace to the rear cover (see my gallery for pics). Gear deflection under HARD acceleration has been known to crack the rear cover in extreme instances. I added the brace for insurance.
-Dean
Old 08-06-2009, 06:44 PM
Great Asp's Avatar
Cobra Make, Engine: SPO 2715
The brace is VERY worthwhile
E
Old 08-06-2009, 07:45 PM
bobcowan's Avatar
I don't own a Superformance, so I could be wrong. But, doesn't the front mount use rubber bushings? If so, that causes flex in the front. But the rear is solidly mounted. One end flexes, and one end doesn't; that's a bad thing with big power.
Old 08-06-2009, 09:41 PM
Banned
The rear mount that attaches to the cover is actually hinged to the rear cross-member. There is a little give there, but it's a pretty beefy hinge (for lack of a better term). Some that have gone to more rigid aluminum spacers in the front have actually ADDED to the problem (i.e. snapping off the ears).
-Dean
