11-19-2009, 05:13 PM
GA
Drill and tap straight on location
Say you wish to drill a hole. Or maybe drill and tap on a chassis or other item that you will not be able to do on a drill press. Get a piece of steel app. 1/2" thick or better, that will fit into the area you are working in easily. Take it to a drill press and drill through so it clears that drill or tap. Now you will be able to use it as a pilot and if lucky you also can clamp it at location. Your taped or drilled holes will be perfectly straight!
11-19-2009, 05:51 PM
MD
You can also buy drill/tap guides that are pre-made and do the same thing. Very handy.....
www.partskeeper.com
11-19-2009, 07:35 PM
Excellent tip, never thought of that. In the end an old airplane mechanic told me "a cross thread is better than no thread"
11-19-2009, 07:57 PM
MD
I bought this one. Worked for me and I was on my back, under the car with a hand held drill first (used this to be sure I was drilling plumb) and then for the tap guide.
http://www.amazon.com/Big-Gator-Tool...8685491&sr=1-1
If you are in a tight spot, tap sockets are also SUPER useful. I would have been screwed without them. http://www.amazon.com/Tap-Socket-Set...8685744&sr=1-1
www.partskeeper.com
11-19-2009, 08:18 PM
OR
Anyone who does metal working & doesn't have one of these has lost a lot of years off of their life for no good reason. Go ahead, laugh! Best $30 bucks you'll ever spend. Guaranteed! http://www.drillspot.com/products/50...c_center_punch
ERA FIA 2088
11-19-2009, 08:56 PM
GA
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
I have had both these tapping guides in my shop for about twenty years and they have paid for themselves time and time again.
Part number 2548A12 Tap & Reamer Aligner, for tight spaces or general use. My unit has a two notches on the bottom so that you can use it on a pipe, round tube or round bar.
Part #2704A12 Manual Tap Driver. I have never snapped a tap using this unit. Holes can also be tapped much faster with it than with a wide handle tap wrench.
http://www.mcmaster.com/#tap-wrenches/=4kumz6
I have seen these at low buck tool suppliers for less $$ I'm sure that the internet will have many sources.
Arthur
11-19-2009, 09:02 PM
I have a drill guide for stuff that I can't get into my drill press. Works great for most things but can't fit everywhere.
Like this: http://www.sears.com/shc/s/p_10153_1...rd=drill+guide
11-19-2009, 09:35 PM
GA
Hyde,
It breaks glass really well also!
Ralphy
11-20-2009, 10:46 AM
Stolen Avitar
GA
Hyde,
Ralphy
Gotta be a story there! I can just see that.
11-20-2009, 10:54 AM
GA
Mostly shop talk. However I saw someone do it!
If your not familiar with this punch, it's spring load. Push on it and bam!
11-20-2009, 10:56 AM
OR
I can imagine
ERA FIA 2088
11-20-2009, 11:09 AM
GA
One of my few talents include being able to sharpen a drill with a pedestal grinder by hand. Learned by the age of 20. Three inch diameter drills are hard but the little ones are a *****!
Cobalt drills are the best, they are the ones with a dull gold finish.
