Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Like Tree2Likes
  • 1 Post By ItBites
  • 1 Post By Voyager
Old 12-22-2011, 12:12 PM
Voyager's Avatar
Cobra Make, Engine: SPF #2920 w/ Keith Craft 408
Default DIY wheel alignments
Anyone having success with DIY wheel alignments?
Noticed there are several tools out there, such as this caster and camber gauge: Camber Gauge and Castor Tools. Suppose you could use strings and lasers for toe.
With 2 sports cars, 2 SUVs, and a pickup, the tool should pay for itself fairly quickly.
Can these types of tools do an accurate adjustment?
Bob
Old 12-22-2011, 12:39 PM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
I bought this. But I will have to wait for spring when my car is done.
Fastrax Camber/Caster Gauge from Eastwood - YouTube
Old 12-22-2011, 02:47 PM
ItBites's Avatar
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
I do mine with turning plates under the tires and I string the center of the frame and measure very carefully to locate strings outboard of the tires from there. I measure camber with a level vertically across the wheel lips using feeler gages at the top, then do the trig to get the angle. I do the same method to get equal caster side to side with the wheels turned to full lock both directions. I dont care about the actual caster value, just that it is equal side to side and I max it out for my adjustment range. The toe is straightforward measuring to the wheel lip horizontally from the strings outboard of the tires. I have never had a better alignment, but it takes me about 2 days to get it perfect on both ends of the car. Way better than any shop I have used.
3Pedals2Pipes likes this.
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
Old 12-22-2011, 04:09 PM
bobcowan's Avatar
Yes, if you're very carefull about what you're doing, you can do this job at home with one of thoose tools. Remember that you're measuring increments of 1/32" and 0.25*. Spend the money and get the right tools, it makes your life much easier. And, I know I'v said this a couple of hundre times before - you can't do a good job with crappy tools.
I use this Fastrax gauge: FASTRAX Gauges - FASTRAX Adjustable Caster/Camber Gauge with this Toe adapter: FASTRAX Gauges - FASTRAX Optional Toe Adapter
You have to understand what you're doing, and why you're doing it. Take your time and don't skip any steps.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 12-23-2011, 03:19 AM
Cobra Make, Engine: ERA #696, Ford 427/482 CO
A Swedish Company, called Gloi AB, will soon release a tool for wheel alignment. Their product will make it very easy.
AliSENSOR Wheel - YouTube
HOB
Old 12-23-2011, 01:19 PM
Voyager's Avatar
Gentlemen,
Thanks for the feedback.
Bob
kitcarbp likes this.
HTML code is On
