Old 07-08-2013, 08:50 AM
Neutral
Default How to keep header bolts from coming loose?
I'm tired of tightening the header bolts every couple hundred miles. I even lost one of the passenger side bolts one time.
I know that several approaches exist (Nordlock washers, safety wire, stage 8 locking fasteners etc). Is there something that actually works?
Simon
Old 07-08-2013, 09:11 AM
I have ARP bolts, and then drilled a hole in each bolt head, then threaded lockwire between each pair of bolts. Been told it works, havent tried it in anger yet.
Crendon 427, in the making
http://crendonreplicas.com/
Old 07-08-2013, 09:17 AM
jwoodard's Avatar
I had Stage 8 lockers on my FE for over 8 years with none ever coming loose.
Jim Woodard
Old 07-08-2013, 09:34 AM
Cobra Make, Engine: Building Mk4 Sold - Factory Five Mk. 3.1
Stage 8's. Haven't had a problem yet.
Scott
Old 07-08-2013, 09:56 AM
CHANMADD's Avatar
My small head bolts have been there since assembly......one or two re checks after the first couple of runs and never look at them again......they do have to be made pretty tight....andvI use a factory sandwhich gasket......without sealer.......another thing...tighten from the center out....
Old 07-08-2013, 10:03 AM
Cobra Make, Engine: jbl
Use RTV
Old 07-08-2013, 10:37 AM
PSB's Avatar
PSB PSB is offline
Cobra Make, Engine: RCR SLC, Graziano 6-spd, LS3
Percy's Vibe-lock header bolts - Percys Vibe-Lock Header bolts - JEGS
Pete
Old 07-08-2013, 11:56 AM
dcdoug's Avatar
I just switched to these and have found them great so far. Also, easier to install than some for the tight spots like the #8 cylinder.
Shop Totally Stainless.com - Home
www.partskeeper.com
Old 07-08-2013, 12:04 PM
For an FE use 1" long ARP bolts, not the cheap 3/4". Use antiseize. Never a problem.
Chas.
Old 07-08-2013, 03:20 PM
x2.
Old 07-09-2013, 03:48 AM
undy's Avatar
Scott
I've used them on every performance car I've ever owned!!!
Too many toys?? never!
Old 07-09-2013, 05:47 AM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
ARP sells a stainless 1" bolt set that is pre-drilled for safety wire. You can get them from Summit. Ask for the NASCAR pack.
Bill
Old 07-09-2013, 10:43 AM
Thanks to everyone for their suggestions! I think I'll give the stage 8 bolts a try.
Simon
Old 07-09-2013, 02:31 PM
Roush #1's Avatar
Cobra Make, Engine: Lone Star Classics / Roush 427 SR
I screw studs (SS) into the head and use a serrated faced nut with lock washers.
Much easier to remove and install the headers if need be as well.
Roush #1
Lone Star Classics
Roush Edition #01
Roush 427 SR #444
Old 07-09-2013, 03:13 PM
Cobra Make, Engine: FFR, 302 Ford Racing Motor
Times 2!
Bob from Simi Valley
Old 07-09-2013, 03:33 PM
fordracing65's Avatar
ARP 2000 bolts vs Stage 8 bolts???
PRIDEnJOY
Old 07-09-2013, 06:04 PM
Dwight's Avatar
Smile
nothing worked on my small block till I installed the Stage Eight. Love them!!!
Dwight
