Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
Old 10-21-2014, 12:53 PM
Default 302 5.0 1985 using T-5
I need a flywheel and clutch set for a build i am doing with my son. I have been told that a LUK Lfw 111 flwheel and a LUK 07-005 is the right combination . Stores here its a special order no rtn. The Flyweek supposedly has multiple holes for use with different pressure plates depending on the nbr of cly's 4,6,8 but are universal. The named clutch set is a 10 inch . Does it make any difference as to the tranny ? c-5 or T-6 . The LUKlfw is 157 teeth and use's a 50 oz damper. I surely would like some insite here.
HTML code is On
